Activity › Forums › Apple Final Cut Pro Legacy › Convert DV AVI to DV MOV and retain timecode
Brent Hilgenkamp replied 17 years, 3 months ago 6 Members · 15 Replies
Arnie Schlissel
June 13, 2009 at 1:25 am[Brent Hilgenkamp] “Buying a Mac, AppleCare, and FCP Studio is quite an investment compared to a $500 laptop doing what amounts to the same thing. In addition to that if a laptop gets dropped or damaged in some way a PC would be a lot cheaper and easier to replace.”
Assuming that your time is worth nothing, that’s true. But when you factor in the cost of your time, it may be quite a bargain to set up a MPB with FCP or at least Veescope or Scopebox.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Brent Hilgenkamp
June 13, 2009 at 9:25 pmAssuming that your time is worth nothing, that’s true. But when you factor in the cost of your time, it may be quite a bargain to set up a MPB with FCP or at least Veescope or Scopebox.
My reason for starting this thread was to find a simple way to get the video files I captured on a PC to work with FCP. If all I would have to do is run a script to process some files or put all the clips in a batch and let it go overnight then I have only added a trivial amount of time to my workflow – not enough to justify the price of the MPB setup. Unfortunately I have not found an automated process to make my timecode work in FCP. Otherwise the workflow is fine and does not take any extra time.
Brent Hilgenkamp
June 13, 2009 at 9:31 pmAn EDL needs both t/c and a reel number. A live captured file doesn’t have a reel number so recapturing off tape via an EDL will be a problem.
Assigning a reel number to a clip is a non issue. It takes 3 seconds in FCP to assign a reel number, and not even having a reel number on a clip is okay if I need to recapture footage that is only on one tape. If it’s more than 1 tape I can selectively pick which clips to capture, or assign reel numbers to the clip.
Why don’t you capture as a .mov on a PC. They can do it.
What software on a PC can do this? That would probably solve all of my issues
Jaap Verdenius
June 13, 2009 at 11:08 pmI don’t understand why you don’t capture from tape into FCP. I mean, if you want to edit in FCP you will have to buy or rent a Mac or MBP with FCP anyway, or am I missing something?
Jaap
Brent Hilgenkamp
June 14, 2009 at 6:24 pmBecause on a busy weekend we can shoot upwards of 100 hours of footage. Capturing everything is not an option.
And yes, I realize that I need FCP to edit with FCP…… I already have the workstations.
