Activity › Forums › Adobe After Effects Expressions › Control the size of one keyframe.
Patrick Evans replied 6 years, 4 months ago 8 Members · 23 Replies
Patrick Evans
April 29, 2020 at 8:26 pmHi all,
I am following through this thread but running into an issue I can’t shake.
I have 4 keyframes on position on an object:
Key 1 is centered on the frame: X=1920
Key 2 is the landing spot X=938
Key 3 is 11 pixels to the left X=927 (938-11)
Key 4 is back to landing spot X=938I am attempting to add a slider to control the landing position of the object, whereby the starting position would be the same, and the end point (with a bit of overspill) will be controlled by slider.
For some reason;
1. My result is that keyframes 2,3 and 4 all get defined as my slider value. The easeout functions as normal.
1. When I loose the interpolation lines, I can get the values to be correct, but there is no interpolation. I can’t get the linear interpretation to work between key-frame 2 and 3 and 4. The value is consistent – therefore no interpolation.Any input super appreciated!
sVal = thisComp.layer("Adjustment Layer 2").effect("Slider Control")("Slider");if (time < key(2).time)
x = easeOut(time,key(1).time,key(2).time,key(1).value[0],sVal)
else if (time = key(2).time)
x = sVal
else if (time < key(3).time)
x = linear(time,key(2).time,key(3).time,sVal,sVal-11)
else if (time = key(4).time)
X = sVal-11
else if (time < key(4).time)
x = linear(time,key(3).time,key(4).time,sVal-11,sVal)
x = sVal
else
x = (value[0]);
[x,value[1]] -
Dan Ebberts
April 29, 2020 at 8:58 pmTry it like this:
else
x = linear(time,key(3).time,key(4).time,sVal-11,sVal);
[x,value[1]]
Dan
Patrick Evans
April 29, 2020 at 9:07 pmAh, a much simpler form of the expression. I was getting hung on the time values and interpolation.
Thanks for the help Dan!
