Activity › Forums › Apple Final Cut Pro › Constrained movement of pucks in Color board.
  • Don Smith
    May 5, 2014 at 8:36 pm
    I often use the Option modifier to ‘gear down’ the movement of a value in the Inspector such as approaching a value with more precision and I found that this also works in the color board. If you scrub the percent or degree by itself then you get fast correction but with the Option key held then the movement slows down and is more precise as you hone in.
    NewsVideo.com
  • Robin S. kurz
    May 6, 2014 at 8:25 am
    For e.g. pulling the volume line/bar of a clip in the timeline it’s actually the CMD key for “gearing down”. Just for the record. 😉
Page 2 of 2
