Activity Forums Apple Final Cut Pro Legacy conforming mpeg 2 ?
  • Jeff York
    January 24, 2010 at 1:48 am
    Just ran up against this myself. Forced to both shoot and deliver in XDCAM (EX 1080i60). Started to build a simple :30 promo and every render had to do a conform.
    To fix it, I went into Sequence -> Settings -> Render Control -> and then change the codec from the default (‘same as sequence codec’) to ‘Apple ProRes 422 [HDV, XDCAM HD/EX only]’.
    Hope that helps someone!
  • Sajit Nair
    April 5, 2010 at 8:53 am
    Hi jeff,
    Wanted to clarify regarding the export of the same. If the render was set to ProRes when you export with recompress off will the export be XDCAM.
  • Jeff York
    April 6, 2010 at 1:18 am
    It will be whatever you specify it to be at export time which includes XDCAM if you wish.
  • Murphy Thelen
    June 8, 2016 at 3:31 pm
    In FCP 6 and FCP 7, this can happen with some codecs (like XDCAM) if you have “Rendered Proxy” turned on in your rendering options.
    Go to Sequence>Render and uncheck Rendered Proxy
    Then go to Sequence>Render All and uncheck Rendered Proxy
Page 2 of 2
