Activity › Forums › Apple Final Cut Pro Legacy › Compressor, “Optical Flow Technology,” 24p to 29.97 – horrid artifacts – semi-rant
John Heagy replied 11 years, 4 months ago 6 Members · 17 Replies
Rafael Amador
February 7, 2012 at 3:40 pm[John Heagy] “For a 30 sec spot in this case yes. For a 5 min or longer interview, absolutely not as the audio will drift out of sync.”
There is not any drift when conforming on CinemaTools.
Video and audio track keeps the same duration.
Video changes the time-base and audio changes the sample rate.
rafael -
John Heagy
February 7, 2012 at 6:17 pm[Rafael Amador] “Cinema Tools changes the sample rate.”
I didn’t think Cinema Tools did that… good to know.
Since CT does not render out a new movie, it is just a sample rate metadata change. If audio was recorded at 48K, a 24 to 23.97 conform would “pulldown” the audio to 47952. To avoid this one could record audio at 48048 so it would pulldown to 48000.
Compressor can pulldown to 47952, re-sample to 48000, and add 3:2 in one step.
John
Kevin Reiner
November 29, 2012 at 8:46 pmDave, thanks for this workflow. It just helped me out.
My videographer insists on shooting 24p even though I argue for 30p to make my life easier. (filmic shmilmic)
So should I just start with a 30p sequence and edit the 24 footage into it? Or should I make your method be the final step and stay 24 up to that point?
… and if so, what if I have an AE sequence that is to be edited into the spot? Do I do that in 29.97 or 24.98?
Mac Pro 2 x 3 GHz 6-Core Intel Xeon
32GB Memory
Dual-channel 4Gb Fibre Channel PCI Express card
Dell Display (23″ flat panel)
ATI Radeon HD 5770
AJA Kona LSi SD/HD capture card
Rourke 16 TB
Flanders 2460SOFTWARE
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig -
John Heagy
November 29, 2012 at 9:09 pm[Kevin Reiner] “So should I just start with a 30p sequence and edit the 24 footage into it?”
No, edit in 24p and then add 3:2 to the finished 24p master. This is the only way to create an unbroken 3:2 cadence across edits.
[Kevin Reiner] “My videographer insists on shooting 24p even though I argue for 30p to make my life easier. (filmic shmilmic)
“The “Cult of 24” is strong.
Hoping the 48fps Hobbit is able to deprogram those who suffer from it.
John
Kevin Reiner
November 29, 2012 at 9:26 pmSo even if I make a smooth 30p AE movie to be inserted into the 24p sequence, frames will be thrown out, just to add pull-down frames on final export.
Makes total sense. 😉
32GB Memory
ATI Radeon HD 5770
Rourke 16 TB
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig -
Jeff Jordan
May 8, 2015 at 5:59 pmI’ve been wondering, is there any way to convert from 24p to 29.97i that automatically recognizes cuts and will not use a mixed frame at the cut? Even when using AE, whenever a cut lands on an interlaced frame, it blends the two different images together into one interlaced frame. Or do most people just live with this artifact?
John Heagy
May 11, 2015 at 11:43 pmI think he understands that. He’s asking if the 3:2 cadence can be “reset” at cut points to avoid mixed cuts. The only way to do this is process every shot separately then put it back together. This avoids mixed cuts buy creates broken cadence potentially at every cut across the show.
The best way is to edit the 24p timeline on frames that don’t produce the mixed cuts.
