Activity › Forums › Compression Techniques › Compressor 4 “Render Farm” :: What is Required?
Ian Liuzzi-fedun replied 14 years, 4 months ago 3 Members · 41 Replies
Doug Daulton
May 30, 2012 at 8:13 pmStar Wars Fan? … Yep. Aren’t we all?
Hmmm. Will check audio and repost.
Doug Daulton
May 30, 2012 at 8:36 pmOK, here is the video, now, with audio!
https://screencast.com/t/b1e0qNtVFc
In addition, here is a screencap of my share monitor, with “hung jobs”.
https://screencast.com/t/yfTvTffqUD9
Ian Liuzzi-fedun
May 30, 2012 at 8:50 pmUncheck allow use of unmanaged services and check that each client needs to be managed. This should allow you to add them to the cluster. Also, I would, to start off with, put a file in that share location and render from and to that location. If that works then you can try a file from a local volume and cross your fingers that it gets copied correctly.
Doug Daulton
May 30, 2012 at 9:10 pmIan,
I followed your instructions and this did, indeed, allow me to add the nodes to the cluster. Everything looked good until I hit “apply”. At that point, “QAdministrator” threw this error:
“Error occurred while creating new cluster: SwampDaemon::NFSPublisher: operation not authorized”
Am now researching.
Doug
Doug Daulton
May 30, 2012 at 9:12 pmOn Gold Leader, there is a QMaster on in System Preferences. It looks to be the 3.5 QMaster as it has none of the settings I assigned.
I moved the cluster controller to Red Leader as it is a more robust box and it is the home of the central data store. Seemed to make sense that would be home base.
DD
Ian Liuzzi-fedun
May 30, 2012 at 9:15 pmTry to add one computer at a time – see if one of those spits out errors. Also, I might try a restart on all of the clients and a qmaster reset. let me know how you make out.
Doug Daulton
May 30, 2012 at 9:43 pmAside from this thread, the following is the only result returned by Google. This does not bode well.
https://discussions.apple.com/thread/3809792?start=0&tstart=0
