Activity Forums Compression Techniques Compressing Feature Length film for streaming/download
  • Craig Seeman
    August 16, 2013 at 12:14 am
    [Marc D'Agostino] “h264 is actually MPEG4 compression, so it’s likely you can use it.”
    MPEG4 involves many encoder specs. MPEG4 part 2 will look very bad compared to MPEG4 part 10 (H.264).
    At matching bit rates the quality likely won’t even be close.
  • Marc D’agostino
    August 16, 2013 at 12:21 am
    Sure, but for thomas’s purposes, h264 is in the MPEG family – so he can use it for a site that specifies it wants some form of MPEG compression. He’ll probably have to use the MP4 extension/wrapper. Is that correct? I’m not sure what are you adding here?
  • Thomas Adjani
    August 16, 2013 at 12:24 am
    Thank you so much, Marc for the detailed reply. I had watched a few youtube vids, but turns out the info was not helpful. I think my not knowing about the possibility of using h264 to get to mpeg was the issue!
  • Thomas Adjani
    August 16, 2013 at 2:33 am
    Yeah, it looks horrible at 2400 streaming : ( and at a small frame no less
  • Craig Seeman
    August 16, 2013 at 2:36 am
    The older MPEG is horrible quality compared to H.264. It’s been retired from common use years ago. There’s really no reason to use it.
  • Thomas Adjani
    August 16, 2013 at 2:41 am
    I used h264. Streaming. Restrict to 2400 kbits/sec.
    best quality. File Format: Quicktime movie. Changed the extension to mp4.
Page 2 of 2
