Activity › Forums › Apple Final Cut Pro Legacy › Complicated Pleasantville Effect
Arnie Schlissel replied 20 years, 9 months ago 8 Members · 11 Replies
Arnie Schlissel
November 30, 2005 at 3:54 pm[John Steventon] “Problem is, they’ve still not Ok’d the edit – and i know they’ll want to change 50% of the shots, meaning I’ll have to do it all over again.”
This is just bad workflow. You should lock the edit first, then start playing with complicated effects. If they think they need to see it as a work in progress, you explain that they don’t because it will take 4X or 8X as long to lock the picture, and 2X or 4X as long to pick the look.
Arnie
https://www.arniepix.com
