Activity › Forums › Adobe After Effects Expressions › Complex Camera Moves
Jonathan Alexander
May 12, 2006 at 6:32 amSound like a good setup, could you show a timeline window or somehow display this setup? I almost follow you, but don’t quite get it all. Thanks, if you don’t mind showing some of your secrets.
–Jonathan
John Mcclary
May 12, 2006 at 1:15 pmHere’s some advice from the best – Chris and Trish
https://www.dv.com/columns/columns_item.jhtml?articleId=181503684They also describe a more advanced setup in the newest DV magazine. Plus the assistant in AE7….
John McClary
Chris Smith
May 12, 2006 at 1:43 pmI have no secrets 😉
1. null_CamPosition
2. null_CamRotation (Parent = null_CamPosition)
3. null_CamShake (Parent = null_CamRotation)
4. Camera (Parent = null_CamShake)I do this so I am never commited to any keyframing that is done, I can still offset things how I wish. For example for the cam to vibrate, it uses up the cam’s position parameter. But if the vibrate is a parent of another null, it moves first from the first null, then it adds vibration to it.
Also if you have rotation on it’s own null, for example, the rotation null can be the camera’s general aiming direction as it moves through space (from the PosNull). But then you still want to override the camera angle to look at something for a moment or to offset it temporarily, then you can still key the camera’s actual rotation and it won’t effect the rotation you already have from the RotNull. Or if your PosNull had a good animation path, but you just think it should be tweaked in space because it’s not quite the right spot, instead of moving all your keys, simply drag the camera layer around (Since it doesn’t have keys itself, it just rides along).
Like when I do a motion track, I paste the track data to a null and not to the video layer itself. Then I parent the video layer to the null. This way dealing with offsetting the layer is as easy as grabbing it in the comp window and dragging it to a new position. Yet it still tracks along because it is parented to the null with the track data.
Chris Smith
https://www.sugarfilmproduction.com -
Richie Grasso
May 12, 2006 at 6:24 pmall AE – all the time
with a couple elements that originated in PS and/or AI
Alexander Gao
May 13, 2006 at 3:10 amnice
Alexander Gao
“When the revolution happens, I’ll be leading it.”
Andy Burmeister
May 17, 2006 at 6:05 pmbanjomamo, is there a way to update this link ? i’d like to see your cam anim
https://71.18.60.52/upload/cloud_love.mov
🙂 thanks
