Activity Forums Apple Final Cut Pro Legacy colour grading on FCP?
  • Jerry Hofmann
    October 19, 2005 at 2:08 am
    Tell me more about the workflow… I’m really interested in Final Touch… would things be better if you exported a self contained movie of the composite? or maybe cc the footage before you edit it in or even just export a self contained movie of the whole project file into FT?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Francois Stark
    October 27, 2005 at 6:55 am
    FT renders (ideally) in 10 bit 4:2:2 uncompressed. Depending on the grades you apply on each shot, it renders almost real-time up to 3 times longer than RT. So it’s not really practical to grade your footage before editing.
    Ideal workflow:
    -Edit content in FCP
    -export as XML, referencing source media
    -import this XML into Final Touch
    -Grade
    -Render in FT – this creates a new set of QT files in a render output folder
    -finalgather in FT – this creates a new XML file that references the new QT files
    -Open FCP and import the XML back into FCP.
    -play out to tape.
    You can imagine the problems in the XML process. multple layers or composites done in FCP don’t translate well.
    Regards
    Francois
  • Adam Sondej
    November 11, 2005 at 1:52 am
    >>The Color Correction tools in Final Cut Pro are outstanding. I’ve been cutting an >HD broadcast series and all coloring is done with the Color Corrector, 3 Way Color >>Corrector, Broadcast Safe and Levels filter. I get absolutely outstanding results.
    Are all the grading effects you mention real time
    through the Kona 2 and Black Magic HD cards?
    If so, are these are generated at 10 Bit quality?
    Adam Sondej
Page 2 of 2
