Activity Forums DaVinci Resolve Colors not right after export
  • Colors not right after export
    Posted by Jean Tertrain on May 12, 2023 at 12:34 pm
    Dear cow people,
    I’m trying to export a video from a .png picture (a song with an image), to a .MOV or .MP4 video file.
    As you can see, the colors do not get right, in the export they are withered :
    Is there a specific setting box I’m not clicking somewhere ?
    A thousand thanks for your help,
    Jean
    Joby Anthony jr replied 3 years, 3 months ago 5 Members · 25 Replies
  • 25 Replies
  • Steven Martillo
    May 12, 2023 at 5:20 pm
    Hi Jean!
    it is likely that the gamma output is not set to rec 709,
    try to put in the color module a “color space transform” node and where it says output gamma, set it to Rec.709. let me know if that solves the problem if not try to set also the output color space in Rec 709.
    I would also like to know in which color space you have the Input color, as that also influences the output color of the material.
  • Jean Tertrain
    May 12, 2023 at 7:08 pm
    Hello Steven !
    Thank you, but both solutions don’t work, the image is even still more withered now.
    Where can I see what is my “color space where I have the Input color” please ?
  • Steven Martillo
    May 13, 2023 at 9:41 am
    you can display the configuration in color management, as shown in the picture. Another possibility is that instead of setting it to rec.709, set it to “sRGB”, I mean the previous solution, try with that color space.
  • Riccardo Luppi
    May 13, 2023 at 3:02 pm
    Hey mate, does the image look correct in you viewer in DaVinci in the first place? DaVinci has an issue interpreting images if their metadata has not the sRGB tag. If that is the case, what you cam do is simply import the png into photoshop amd then save it as JPG. That will add the proper tag to the image and it will be displayed correctly in DVR
  • Jean Tertrain
    May 14, 2023 at 8:04 pm
    Hey, thank you, but how do I get to this window ?
  • Steven Martillo
    May 14, 2023 at 9:50 pm
    to enter that setting you should click on project settings, which is right in the lower right corner of the screen. but if you have it by default and you have not touched anything, no need to go there because it will be correct, I recommend that you do the srgb change the image from davinci or as Ricardo has said, you can also do it through photoshop both options would solve the problem of color conversion in davinci.
  • Jean Tertrain
    May 15, 2023 at 12:15 pm
    Hey, thank you Steven and Riccardo 🙂
    I changed the color space to “sRGB”. Within the parameters, and by adding a node in the color page.
    It does nothing, the image is still not faithful to the original.
    It’s a cover album, so I would appreciate not to convertit it to a very compressed format like .jpeg.
    I expect Davinci to read a format as universal as .png without any problem or complicate work-around.
    Anyone here know the solution ?
  • Riccardo Luppi
    May 15, 2023 at 12:20 pm
    Could you link the original file here? I would like to check it out offline on my end!
  • Jean Tertrain
    May 15, 2023 at 12:24 pm
    Here it is brother :
    https://we.tl/t-sg9b560EHZ
  • Riccardo Luppi
    May 15, 2023 at 1:34 pm
    It is indeed the tagging issue. Use this jpg: https://we.tl/t-dI5cEghEjY
    this will be correctly read by DVR.
Page 1 of 3
