Activity › Forums › Apple Final Cut Pro Legacy › Color Smooth 4:2:2 problems
Karl Richter
May 27, 2009 at 8:23 pmNope. This was happening before.
I actually just updated today and it changed nothing. -
Rafael Amador
May 30, 2009 at 3:16 am -
Brent Streeper
September 4, 2009 at 12:13 amI just ran across this same problem. It seems to be a bug with just the Color Smoothing filter and not the keyer.
Go into the Video Processing tab of the Sequence Settings window and switch “Render all YUV material in high-precision YUV” to “Render in 8-bit YUV”. That seemed to take care of the problem for me.
Hope this helps even though it’s a few months late! -
Rafael Amador
September 4, 2009 at 2:15 amHi Brent,
I’ve ben reading the thread again.
The think is that it doesn’t makes sense applying a 422 Chroma Smooth filter in footage that is already 422.
You use it in 411/420 footage. In 422 footage (DVCPro50/HD) makes sense a Chroma Smooth 444 filter if you want to see any improvement .
Rafael -
Karl Richter
September 4, 2009 at 2:17 amThe smooth filter does make a difference. It’s small, but it’s there.
