Activity Forums Adobe Premiere Pro Color / luminance correct set up?
  • Jim Wiseman
    November 15, 2011 at 10:23 pm
    If it is for broadcast, you will definitely want to keep it in SMPTE specs. 16-235 YUV. 0-255 is an RGB computer space. You can work in it, but it must be tweaked for broadcast. Trust the YC scope if you do not have good monitoring. Don’t let any of the whites go above 100 IRE units, or any of the blacks go below zero. I would keep the blacks just above that. Then you should be alright. You can use Curves or Proc Amp or several other effects in Premiere to control luminance. Fast Color Corrector is a good effect to control saturation and quick color balance problems. There are several good color correction tutorials on this forum and adobe.com
    As far as what you are bringing in from Vegas, I don’t know that program. In fact, I am just beginning on Premiere Pro from Final Cut/Media 100 Suite/Avid. I’ve been doing color correction every day on Premiere Pro 5.5.2, and exporting ProResHQ clips. But color space and luminance issues remain the same on output.
    It still sounds as if you are having a conversion problem between these programs/codecs spaces. Someone here or on the Vegas Forum may be able to help you further. Good luck.
    Jim Wiseman
    Sony PMW-EX1,Pana AJ-D810 DVCPro, DVX-100, Nikon D7000, Final Cut Studio 2 and 3, Media 100 Suite 2.1, Premiere Pro 5.0 and 5.5, AJA ioHD, AJA Kona LHi, Avid MC, Hexacore MacPro 3.33 Ghz 24Gb RAM 120GB SSD, Macbook Pro 17″ 2011 2.2 Ghz Quadcore i7 8Gb SSD, G5 Quadcore PCIe
  • Jim Wiseman
    November 15, 2011 at 10:33 pm
    If it is for broadcast, you will definitely want to keep it in SMPTE specs. 16-235 YUV. 0-255 is an RGB computer space. You can work in it, but it must be tweaked for broadcast. Trust the YC scope if you do not have good monitoring. Don’t let any of the whites go above 100 IRE units, or any of the blacks go below zero. I would keep the blacks just above that. Then you should be alright. Some NTSC distribution cannot to drop below 7.5 units (setup) Digital is changing that spec in a lot of applications, though. You need to check with the quality control engineers of your distributor. You can use Curves or Proc Amp or several other effects in Premiere to control luminance. Fast Color Corrector is a good effect to control saturation and quick color balance problems. There are several good color correction tutorials on this forum and adobe.com
    As far as what you are bringing in from Vegas, I don’t know that program. In fact, I am just beginning on Premiere Pro from Final Cut/Media 100 Suite/Avid. But color space and luminance issues remain the same on output.
    It still sounds as if you are having a conversion problem between these spaces. Someone here or on the Vegas Forum may be able to help you. Good luck.
    Jim Wiseman
  • Jim Wiseman
    November 15, 2011 at 10:36 pm
    Sorry for the double post, thought I was editing. The bottom post has additional information.
    Jim Wiseman
  • Ronaldo German
    November 16, 2011 at 12:29 pm
    Thank you very much Jim.
    By the way, I couldn`t find PRORES as an export option in quicktime inside Premiere Pro 5.5
    Regards
  • Jeff Brown
    November 16, 2011 at 2:06 pm
    –if you are on Windows, you cannot export to ProRes. Only import. (thanks a lot, Apple)
    -jeff
  • Ronaldo German
    November 16, 2011 at 3:57 pm
    Thank you Jeff. Yes, I`m on Windows.
  • Jeremy Salo
    December 29, 2011 at 11:07 pm
    I am editing footage from Sony EX1 cameras in Premiere Pro CS5, and using the YC Waveform scope. The levels look broadcast safe while previewing, but when I render the work area, they exceed past 100 and below 0.
    Any idea why?
    I also posted on the Adobe forums with more information.
    https://forums.adobe.com/message/4107830
Page 2 of 2
