Activity › Forums › Apple Final Cut Pro › Color Grading Tools to augment FCP X
Eric Santiago replied 14 years, 1 month ago 5 Members · 15 Replies
Oliver Peters
July 28, 2012 at 9:41 pm[Michael Holmes] “You don’t see real time as important because you are normally working with a frame at a time……correct?”
The interaction with the controls would obviously be very responsive. By real-time, I’m talking about the playback frame-rate when you play the timeline with corrections applied. In regards to Resolve, the more color correction nodes you apply to individual shots, the more impact this has on playback performance.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Michael Holmes
July 28, 2012 at 9:53 pmOK.
One more question and I’ll quite bothering you.
I am scoping out hard drives.
I am using only SATA II drives. I tried SATA III drives in my 2010 Mac Pro in March and I had to return them……lots of problems.Are you using SATA II drives in the RAID 0 setup?
Oliver Peters
July 28, 2012 at 10:34 pm[Michael Holmes] “I am using only SATA II drives. I tried SATA III drives in my 2010 Mac Pro in March and I had to return them……lots of problems.”
I’m on a Mac Pro 4,1 (purchased 2009). Depending on whether I’m using raw drives for archiving or for media, I’ve used a variety of WD Caviar (Greens and Blacks), SATA II. These are the 3Gb/s drives. At a client site, he’s used the Seagate Barracuda XT drives. Media drives should be SATA II, 7200RPM. I don’t believe SATA III drives are internally-compatible with any Mac Pro tower, but I could be wrong. I believe those are for some of the newer drive array chassis.
– Oliver
Orlando, FL
Michael Holmes
July 28, 2012 at 10:42 pmThanks again for all the help!
I am sure I will be back soon after I am pummeled by Resolve. 🙂 -
Eric Santiago
July 28, 2012 at 10:56 pm[Michael Holmes] “(1) Yes, I recognize the masking will be tedious and time-consuming in any case. But the FCP X masking just seems crude and cumbersome to me. I was hoping that there would be some easier tools to accomplish this.”
Have you considered jumping into deeper waters like After Effects?
If of course you have the budget and resources.
Ive had to do numerous lighting fixes with live events such as bands, shows and public speakings.
You have pre-plan no matter what NLE you are using.
