Activity › Forums › Apple Final Cut Pro Legacy › color correction in Final Cut Pro
Benjamin Daines replied 18 years, 7 months ago 9 Members · 21 Replies
David Roth weiss
January 29, 2008 at 1:45 am[Ami Cuneo] “In response to David’s questions, no, I hadn’t heard of adjusting the 7.5 IRE to 0 — I actually don’t know what that is…!”
When I get done rendering I’m going to post a little demo for you… Its done using the 3-Way CC.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
Bret Williams
January 29, 2008 at 4:46 amMost DV cameras don’t even have this functionality. And when they do, it’s turned off by default. What camera are these tapes coming from? Someone is depriving you of the additional luminance range you get from DV format and loading in via firewire or sdi.
Or, by chance are you digitizing your DV tapes via an analog input like component. DV decks should of course add setup to the analog output, and strip it on analog input. The same goes for a card like your LH that has component in. On component in you should see setup, and it should have to be stripped to 0.
David Mcgiffert
January 29, 2008 at 6:05 amAlan,
I want to also add how interesting and clear that link is.
Thanks, I learned alot.David
David Roth weiss
January 29, 2008 at 7:49 am[Bret Williams] “Or, by chance are you digitizing your DV tapes via an analog input like component.”
Via firewire Bret, hot off the press, from numerous Sony and Pany cameras.
David Roth Weiss
Director/Editor
Alan Okey
January 29, 2008 at 9:01 pm[David McGiffert] “Alan,
Thanks, I learned a lot.David”
You’re quite welcome. It really is astonishing to me how many people are not aware of this issue. Then again, if everyone knew everything, there’s be no consulting work left for me to do!
Bret Williams
January 29, 2008 at 10:55 pmWell that’s just bizarre. Has anyone else seen DV come in with 7.5 ire except in the odd instance that the shooter decided to change the default setting? I think I’d have a little talk with them!
I get P2 stuff, miniDV, DVCPro, HDV, DVCam and have only seen it once. The facility was delibrately doing it to match their betacams on analog output. Of course, they then had to turn off setup on the output of their decks, otherwise they’d end up with 15ire. What a mess.
Walter Biscardi
January 30, 2008 at 1:40 am[Bret Williams] “Well that’s just bizarre. Has anyone else seen DV come in with 7.5 ire except in the odd instance that the shooter decided to change the default setting? I think I’d have a little talk with them!”
Honestly, no, it’s always been 0 in our experience.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
David Roth weiss
January 30, 2008 at 11:09 pmBret,
As I was color correcting earlier today I actually paid attention to the numbers, and it turns out that blacks I was refering to are not at 7.5, but they aren’t at zero either, and thus do need to be lowered on almost all DV that comes my way.
David Roth Weiss
Director/Editor
