Activity › Forums › Apple Final Cut Pro Legacy › Codec not found. You may be using a compression type without the corresponding hardware card.
Erg Into replied 13 years, 11 months ago 12 Members · 14 Replies
Fredy Schwerdtner
June 26, 2011 at 3:53 pmLooking for the same kind of problem when trying to render a prores sequence, I could solve the problem changing the compressor render settings for the sequence from “same as sequence codec” to “apple intermediate codec”. Doing that I could render and export it.
iMac 2.7 GHz Intel 4 Core i5
16 GB memoryMacBook Pro 17″
2.5 GHz Intel Core 2 Duo
6GB 667 MHz DDR2 SDRAMOWC RAID 5 with 3TB
(2) External HD LaCieMac (400/800 FW and USB)with 500GB -(2) USB External HD Western Digital (in cases) with 750GB
OS X 10.6.5
Final Cut Studio “3” -
Alain Furcajg
December 2, 2011 at 6:04 amFixed it! Changed render settings of the sequence to HDV as opposed to Prores 422. Other codecs probably work but not Prores 422 apparently.
Had this error message: “Codec not found. You may be using a compression type without the corresponding hardware card.” when was trying to export my sequence – or even just render. Been editing a project with multiple codecs and stills and thought it was because I was using jpegs – as opposed as png or tiff – in all different frame size. I isolated it and it was actually some vertically shot footage – on iPhone or Flip but converted to Prores 422 – that was creating the issue. SO i changed the settings of my sequence to render in HDV as opposed to Prores. Somehow the supposedly flawless Prores 422 codec is pretty fussy about vertically shot footage – and some jpegs in different frame sizes too I’ve read – and wouldn’t render. So rendered and exported to h264 just fine!
Erg Into
October 15, 2012 at 6:33 pmI had this problem, and I discovered that it was due to having CMYK graphics in my sequence. As soon as I converted them to RGB, everything worked perfectly.
Hope this helps!
