Activity Forums Apple Final Cut Pro Legacy “Close Gap” Shortcut – FCP 7
  • Julia Wells
    April 20, 2010 at 6:44 pm
    Thanks for this thread- even if it’s a bug it’s nice to know i’m not alone. I’m a heavy close gapper as well and it’s driving me nuts!
  • Regg Skwarko
    June 6, 2010 at 9:42 am
    Hi there,
    I’m having the same problem.
    Until Apple comes up with a fix in their updates, in the meantime, rather than Control G-ing it, or shifting the timeline to the right of the gap etc, try highlighting the gap and hitting the delete key.
    Its no “right click => close gap” but its something.
    Cheers
  • Joel Godin
    July 18, 2010 at 4:50 pm
    I found the same thing as Frank. In other words “I second this lack of motion”.
  • Ted Griffis
    August 12, 2010 at 7:17 pm
    Same issue as others, though this does not effect every project oddly. Beyond annoying! If you are a keyboard editor touching the mouse is not an option as it slows you down tremendously.
    A work around I’ve been using is the “Mark Clip” Function “X”. you can mark the gap and then hit delete, this is the fastest workaround I’ve found to date.
    cheers,
    Ted
    Ted Griffis
    GriffisART
    https://www.griffisart.com
  • Jaap Verdenius
    August 12, 2010 at 9:18 pm
    You can also click on any track inside the gap and then hit backspace – fastest workaround for me.
    Still looking forward to the fix though…
  • Garrett Gibbons
    August 12, 2010 at 9:25 pm
    I agree with Ted, though: taking fingers away from the keyboard to position the mouse over the gap… way too time-consuming. Seriously. I like the x-delete combo, personally.
    http://www.garrettgibbons.com
  • Don Swaynos
    September 3, 2010 at 4:32 am
    I just upgraded and just ran into this. It’s very annoying, but nice to know I’m not the only one.
Page 3 of 3
