Activity Forums DaVinci Resolve Clips are not being found
  • Gregory Dillard
    May 13, 2013 at 11:02 pm
    I am having the same issue. I have the Canon c300 and I shot an entire project using the 720p 60fps all slo mo. My workflow is FCP X, then export an XML to DaVinci RESOLVE. I did change the settings to “handle mixed format” and it still shows up as saying all of my clips can’t be found.” This only happens when I use the slo mo clips from the Canon c300, which are 720p 60fps. For the record when bring in an XML thats 1080 it works like a charm. I tried to see if I could just import the clips and that works also. Why isn’t the XML working? Thank you in advance.
    Gregory Dillard
    grapeseeker.tv
  • Aimie Burns
    June 3, 2013 at 8:16 pm
    Hi Andrew,
    I made a new project, and selected “enable mixed framerates’ and I’m still having the same issue. Once I have imported the footage, and I check my project settings, the option for “mixed framerates” is still checked, but it is greyed out.
  • James Hark
    July 13, 2016 at 5:21 pm
    did you ever find a solution!?!? Im having this EXACT problem with my 70D!
  • Dwaine Maggart
    July 13, 2016 at 9:53 pm
    If you browse to the clip location in the Media page Library/Media Storage area, do you see the files listed?
    If so, if you select one, do you see it in the viewer?
    What type of files?
    What version of Resolve?
    What type of system and OS?
    Do other files, like ProRes work OK?
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • James Hark
    July 20, 2016 at 6:23 pm
    Thanks for your response!
    No they aren’t in the media pool.
    “What type of files?” I shoot with a Canon 70D, So I use 1920×1080 24fps for anything not slow motion. I use 1280×720 60 fps for slow motion shots. Its the slow motion shots that are not loading.
    Version is 12.3.2.008
    Using PC with Windows 10 if thats what you mean by system
    Yes ProRes files work I have had them before. But I think I ran into a similar issue with different frames and resolutions. But forget that for now please. I am really concerned with how to get my 720 60 fps frames to import with the rest of my clips in the .xml file I am trying to load in from Sony Vegas.
    It says no overlap between specified target timecodes
Page 2 of 2
