Activity › Forums › Apple Final Cut Pro Legacy › Client monitor solution ideas?
  • Ryan Mance
    March 30, 2007 at 1:10 pm
    If you decide to go the Canopus route, Simply Computing on West Broadway has them for $299, which is the cheapest I’ve found them in Vancouver. They’ve got a couple in stock right now, too.
    I’ve borrowed the ADVC-300 from work, and it’s a pretty solid little device. Firewire-powered, analog input for capturing and analog out for monitoring. The DVI-to-RCA adapter Apple offers is not in the same league for monitoring. I use one for Shake output, but if you want Final Cut support, Canopus is probably the way to go.
Page 2 of 2
