Activity Forums Apple Final Cut Pro Legacy Chroma Key and Effects Questions
  • Jochem Smit
    June 18, 2010 at 9:35 pm
    Hi Dave,
    Thanks a lot.
    I only work with the render queue, no exports..
    I indeed did use apple prores before and didnt get the alpha transparency i desperately needed in FCP.
    Afterwards I used animation (millions of colors+ & RGB+ALPHA) and it worked so thats cool!
    Since I work ok a macbookpro laptop it takes me 25 minutes to render a shot of one minute (in the queue) with those settings. Apple Prores 4444 seems to be even heavier. Which codec do you advice me for time and alpha sake?
    Do you for example think straight can reduce the render-time compared to premuliplied? Thusfar I only did premultiplied and it resulted in the result i need….
    Finally… my reason not to edit my whole sequences (its no shots, its whole timelines) of fore and background in AE is the fact that I dont feel secure to the interface of the sequence, there is no sound, there is slowmotion, i cant easily scroll through the timeline etc… I’m even not sure if AE is honest to my resolutions and image ratio’s… This all caused by the fact that I’m new to AE. I want to be back in FCP with my Alpha channel asap:)…
    Thanks for time and effort,
    Jochem
Page 2 of 2
