Chroma is not fully removing background
Dimitrios Papadimitriou replied 7 years ago 5 Members · 18 Replies
Andrew Taylor
August 30, 2019 at 11:08 pmCan you explain what you mean “use a second chroma key and map it to the remaining green”
Do you mean produce a video using chroma 1 .
then redo do it? and produce it again?I’m not sure what i’m doing
The background is green
Should i be playing around with these extra chromas unti the b/ground is black? -
Andrew Taylor
August 30, 2019 at 11:14 pmthis is using 1 chroma only
https://www.screencast.com/t/klZpYLq8oqobThis is using 2 chromas with some slider to make bg black.
Not sure what i am supposed to be doing here.
I want to totally get rid of the green bg.https://www.screencast.com/t/z4Mp9UC9N
Francois Pénzes
August 31, 2019 at 1:20 pmHi Andrew
First off, as Graham mentioned in his 4th comment, lighting is everything. Especially for Green (or Blue) screening.
However, when I am faced with this predicament, I usually ”cheat”.
By that I mean ”change” the green background to make as even as possible by using Color Correction (Secondary)
There are a bunch of tutorial out there explaining how to make it happen. Graham posted one a while back. Not exactly what you need to do but it teaches you how the process works and from there know how to make it happen.
https://reels.creativecow.net/film/grazie-2colour-and-black-and-white-and-grey-background
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 16, User since Vegas 3.0\’\’When the cutting stops, the editing begins…\’\’
Graham Bernard
August 31, 2019 at 2:45 pm[Francois Pénzes] “Graham posted one a while back. “
Hi Francois! Wow that was 10 years ago. Actually, it’s still not a bad tutorial at all!
Francois is most likely alluding to the Controls we can bring into use in that 2nd Colour Corrector. Takes a bit of tweaking and adjusting.
* Grazie
PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
Cameras: Canon XF300 + PowerShot SX60HS Bridge -
Larry Brewer
September 9, 2019 at 12:28 amAndrew, the green trash in the lower section of the frame is due to the green screen not being lit evenly. (it’s darker at the bottom of the screen than at the top. Having said that, even after you get the green background lit properly, you’ll never get the best chroma key with Vegas keyers. Third party keyers like BCC do a better job. And After Effects works the best.
September 19, 2019 at 4:16 amHey Grazie are you saying you’re trying to tell him to light green screens evenly? I didn’t know he was filming it himself, I was just suggesting one way to get rid of the remaining green.
