Activity › Forums › Adobe Encore DVD › Chapter Playlist – Disfunctional in 2_0
  • Yes you are spot on with this example
    [Jeff Bellune] ”
    1. Same playlist.
    2. Chapter 3’s end action (only in the playlist) is to go to chapter 6 and have it play.
    3. If you want chapter 6 to play after chapter 3, then all you have to do is list chapter 6 after chapter 3 in the playlist – no end action needed.”
    But lets say for example I want to go to a splash screen after chapter 3 that may have supportive info, or a link to another timeline, or a skip button, which would take me back to chapter 6. Does that make sense? The work around would be to create individual chapter playlists with appropriate end action links. That will work, but is more cumbersome.
    The following was copied directly from the help files.
    Chapter playlists function much as playlists do, but provide a means of playing a single timeline
Page 2 of 2
