Activity › Forums › Adobe Premiere Pro › Changing The Video Height & Width Inside The Sequence Box
Anthony Uccello replied 15 years, 8 months ago 2 Members · 14 Replies
Jeff Pulera
January 7, 2011 at 2:35 pmIn Export settings, under the VIDEO tab, looks for FIELDS, it can be set as Lower, Upper, or Progressive
Jeff
Anthony Uccello
January 7, 2011 at 5:22 pmThanks Jeff
You’ve been a great help!
I had tried that and the video still vibrates so Ive posted this issue on the adobe forums.
Really though thank you for the help you’ve been of great assistance
Jeff Pulera
January 7, 2011 at 5:34 pmOn the YouTube output, was the video scaled (resized) at all? Fine details can shimmer especially when scaling. Right-click the video clip in Premiere timeline and in Field Option, choose “Flicker Removal” and see if that helps.
Jeff
Anthony Uccello
January 7, 2011 at 6:08 pmThanks Jeff
Unfortunately the only thing that works atm, is when I go clip, modify, interpret footage, then I match the field order to source. But then Im faced with a new problem, the resultant file is HUGE. 5 seconds of footage is 20mb
