Activity › Forums › Apple Final Cut Pro Legacy › Change Speed of Audio while Maintaining Pitch
  • Helmar Sowick
    November 11, 2009 at 10:38 pm
    Sample rate is the how many samples per second the audio is measured in. Its the 44.1k 48k thing.
    Imagine a squiggly audio waveform. If you zoom way in on it, you can see the smooth curves turn into little staircases.That’s the only way to digitize an analog signal. Each one of these steps is a sample. If you audio is 48k, there are 48,000 steps per second.
    FCP will allow you to manipulate the audio down to the sample, so in a sense, audio is really 48,000 fps.
    This has nothing to do with my question though 🙂
  • Helmar Sowick
    November 11, 2009 at 10:40 pm
    so, just like with everything that doesn’t come through in an omf, you mix down the audio (with handles) and overcut it before making the omf. Or, you don’t, and you just use it as a reference for the mixer to redo professionally.
  • Chad Brewer
    November 12, 2009 at 1:33 am
    Paul is right. I’ve learned that jumping out of FCP into Soundtrack Pro and exporting back into FCP for things that Soundtrack Pro was designed to do that FCP was not designed to do can save you time in certain circumstances.
    chad
    https://www.televersions.com
  • Chad Brewer
    November 12, 2009 at 7:17 pm
    Paul,
    I just found your aspect ratio converter software.
    Awesome!
    chad
    TeleVersions Broadcast Video
  • Paul Figgiani
    November 12, 2009 at 10:51 pm
    Cool Chad.
    Ping me if you would like to have a copy of ver. 2.0 with the Attribute Inspector.
    -paul.
  • Julie Dole
    December 1, 2009 at 7:17 pm
    For a speed change of 105%, we entered a value of -200 to correct pitch.
    Your mileage may vary… 😉
  • Chad Brewer
    December 25, 2009 at 1:06 am
    Yep.
    It depends on where your car was made.
    Chad Brewer
    Senior Tape Operator
    TeleVersions
  • Isazaly Mohd isa
    January 2, 2010 at 8:15 am
    I have created an FCP Speed Chart which I use to do Music Videos with, back in 2007. I wanted all my speed change audio playback to have the EXACT PITCH of the original music.
    Not sure if this is useful. Anyway, its been tested in a PAL environment. Enjoy!
    Download PDF here: https://dl.dropbox.com/u/1686339/speed_chart.pdf
    Isazaly Mohd Isa @ Zalee
    Apple Certified Trainer
    Malaysia
    https://isazaly.blogspot.com
  • Isazaly Mohd isa
    January 4, 2010 at 10:01 am
    Sorry, I didn’t realize the link was the same thing.
    Anyway, feel free to comment on it. Cheers.
    Malaysia
  • Elyse Hendricks
    January 3, 2013 at 9:31 pm
    This worked great, thanks a million!
Page 2 of 2
