Activity › Forums › Adobe Premiere Pro › Change Sequence Settings
  • Jon Barrie
    August 23, 2009 at 12:18 pm
    I don’t think the suggestions for this problem are completely addressing the fact that without replacing each cut made with the mutlicam footage this project can’t be fixed in PPro.
    open the PPro in AE where you get to see the cuts in the project. Then resize the comps (which can be done at any stage of the edit), reresenting the seq’s of the multicam, then save it out as a PPro project. Reopen it in PPro.
    hopefully this will make all the seq’s used in the HD framesize you need, including the mutlicam stuff.
    I have not tested this, buthopefully the Multi-cam concept kinda holds cuts timing, but it may not as After Effects doesn’t have a multicam function.
    There is a lacking in the way multi-cam editing is not collapsable in PPro workflow.
    Sorry my friend. I think the only true solution to your sitution is to make a duplicate of the multicam seq with a HD timeline – then one cut at a time replace with the replace>match frame function with hitting M key to match with SD multicam cut and find the timecode of that seq and know the camera angle then assign the replaced HD Multicam build the correct camera angle.
    – JB 🙁
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Jon Barrie
    August 23, 2009 at 12:24 pm
    The only other way to work this out quicker than my last post is if your multicam edit actually runs in realtime.
    Add the HD multicam build above the one that has the SD one, use the SD edit and jump to the cuts in it and have the timeline zoomed in so you can see the camera angle, have the multicam window open and have it looking at the track you have the HD multicam nest and select the cam angle as you jumpt to the cuts of the original.
    I think this is a great learning experience that HD projects don’t lend themselves to SD Editing and a fun time workin in Multicam projects with an offline SD/DV to then attempt to go up to HD/HDV.
    – JB
    Jon Barrie
    aJBprods
  • Vince Becquiot
    August 23, 2009 at 3:12 pm
    Yep, sorry, I missed the multicam part in your last post.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Arvin Villapando
    August 24, 2009 at 5:38 pm
    Thanks for all the help guys. Tryin some of this out. Will let you know soon.
  • Fennie Ng
    December 10, 2009 at 7:58 pm
    I have the same problem. I took Arvin’s suggestion below. I got everything to work except the multicam timeline still show 720×480 instead of matching 1280×1080 to my source timeline. Does anyone know what gives?
    Hi Arvin,
    Yes, I tried it again with DVC Pro.
    So just to confirm one last time, copy SD clips to new HD Timeline, select one of the clip, right click “Reveal in Project”. Then right click that clip in Project manager and select “Replace with Footage”, then choose your HDV replacement.
    If that doesn’t work, try renaming the HD files to something else, but it should work that way.
    Vince Becquiot
    Kaptis Studios
  • Arvin Villapando
    December 11, 2009 at 4:05 am
    Sorry it took so long to post the solution to this. Jon I think actually posted it.
    K,
    1) Using the track selection tool select all the multi cam clips in your time line that you want to convert to HD
    2) Right click and select replace with AFter Effects Compostion. After Effects will open up with the the comp loaded up.
    3) Open the Multi Cam Composition and adjust settings to hd. Do the same with the Nested Comp.
    4) Export the project as a Premiere project under file export
    5) Open the project in Premiere. You’ll need to remember which cuts use which camera because exporting from after effects reverts all the multi cam clips to camera 1
  • Fennie Ng
    December 11, 2009 at 5:48 pm
    Arvin, you are a life saver. I got it to work, except one of the video on my source timeline is missing. The audio is still there. Weird.
  • Fennie Ng
    December 11, 2009 at 8:55 pm
    After couple hours playing around, I realize all video and audio tracks must be turned on in order for AE to export them.
    Your advice worked out perfectly. Thanks
    Fennie
  • Arvin Villapando
    January 18, 2010 at 3:23 pm
    Glad to hear it worked! sorry got real busy again.
  • Pablo Geh
    January 19, 2012 at 3:57 am
    SOLVED!
    hi guys!
    I just registered to share the solution to this awful problem, lets hope adobe cs6 modify the sequence settings so we can adjust any time, just like in AE.
  • Problem:
  • wedding Sequence edited in 720p, (it was shot in 1080, but to edit in a slow PC i set the sequence to 720×1280, knowing that later on i just copy and paste the clips into a new sequence.
    I Had to use the multicam, so I nested the 2 (1080) clips, but cause i was working in a 720 sequence, the nested sequence was also 720.
    when i tried to adjust the sequence size it just wasn’t possible.
    Tried the tips you guys recommended here, but the first one about importing to AE, its just not a good way, couse you still loose all the multicam information.
    The second way, I put the new nested 1080 comp above the 720 multicam, and start imitating the cuts, after 2 hours and wasn’t getting to the middle of it i decided to try another way.
  • The SOLUTION:
  • -Save the project under a different name.
    -open a text editor
    /looking around i found that some places it said: 0,0,1280,720
    So, as my project wasn’t supposed to have any 720 videos or sequences,
    -REPLACE (inside the text editor):
    Find what: 1280,720
    Replace with: 1920,1080
    -SAVE the file changes.
    Open in premiere, and its done,
    Less than 2 minutes job!
    Hope someone find this helpfully, and keep it in mind for the future!
    PS: SAY NO TO SOPA
    Pablo.
Page 2 of 3
