Activity › Forums › Apple Final Cut Pro Legacy › Change Sequence Settings to Original Media Specs
Jeremy Garchow replied 16 years, 2 months ago 3 Members · 12 Replies
Paul Ewen
July 15, 2010 at 12:44 pmThanks for the great tip. Will try it out. Why won’t FCP fix the frame rate issue? Not like anything was redigitized or exported at a diff rate? Avid has the same issue. It is all software and 1’s and 0’s. Seems like there should be some programming genius who could do it.
Paul Ewen
Owner/Editor
http://www.ewenindustries.com -
Jeremy Garchow
July 15, 2010 at 2:41 pmEditing is all based on timing. I guess they don’t want to mess that up. After Effects has been able to do this for years.
I think with NLEs it would do more harm than good.
The XML exporting in the other thread might work, but none of your clips will have any relation to the clips in the bin after that process. It’s worth a shot, I guess.
