Activity › Forums › Square Box CatDV › CatDV Server on 10.6 – java error and reinstall
Bryson Jones replied 12 years, 6 months ago 4 Members · 12 Replies
Scott Goddard
February 7, 2014 at 5:30 pmI know this is old but I have found out why this error occurs. I imagine that you are running an ISCSI SAN?
I have constant conflicts with the process ‘iscsid’ daemon affecting the rmi registry and essentially using port 1099. I am using ATTO XTEND SAN.
I can’t get the server to run on port 1099 unless I kill the iscsid process. This process seems to run on startup even if you take ATTO off automatic logon.
If you look in the log:
at com.attotech.iscsid.Daemon$RMILoaderSPI.loadClass(Daemon.java:2003)
Thats the issue. ISCSI is common for video SAN environments. There seems to be some kind of conflict here.
Rolf, can you offer any solutions?
Scott Goddard
Neo Verite Limited
https://neoverite.com -
Bryson Jones
February 7, 2014 at 5:40 pmThat’s why port 1199 was invented. 😉
When we use Atto stuff we just move the system to 1199. No problems with that as long as your address in the client is something like:
server.domain.net:1199
or 192.168.x.x:1199
bryson
bryson “at” northshoreautomation.com
