Activity › Forums › Apple Final Cut Pro Legacy › Capturing live from an HVX200
  • Cody Walters
    April 29, 2011 at 9:53 pm
    Set your recording format to 480i and Rec Mode to DV. Then match the settings in final cut. Then I would believe you can hit record on the Panasonic and do a capture now in final cut.
    Mac Pro 2.26GHz 8 Core
    16 GB 1066 MHz DDR3
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
    http://www.codywaltersvideo.com
  • Buddy Englett
    May 2, 2011 at 3:57 pm
    My recording format is 480i, 720/30P and Rec Mode is DV. I have FCP set to non-controllable device and capture settings set to DV NTSC Animorphic (fps 29.97).
    Again, I can see the camera output in FCP when the camera is set to record to tape, but I still get “Preview Disabled” when in P2 mode.
  • Jeremy Garchow
    May 2, 2011 at 4:40 pm
    [Buddy Englett] “My recording format is 480i, 720/30P and Rec Mode is DV”
    This doesn’t make any sense.
  • Buddy Englett
    May 2, 2011 at 4:53 pm
    Sorry, Recording Format is 720P/30P, 480i Record Mode says DV.
  • Jeremy Garchow
    May 2, 2011 at 4:58 pm
    Everything should be in 480i dv25 (or dv50). If you don’t want to record in HD, then set your camera for SD.
  • Buddy Englett
    May 2, 2011 at 5:02 pm
    How do I do that?
  • Jeremy Garchow
    May 2, 2011 at 5:27 pm
    In the recording setup menu of the camera.
  • Buddy Englett
    May 9, 2011 at 4:11 pm
    I’m sorry, I don’t understand. In the Recording Setup menu The first item is Rec Format which is set to 720/30P. The second item is 480i Record Mode. To the left of it reads “DV” in blue text, but I’m not able to change it. I see nothing that allows me to switch between HD and SD recording.
Page 2 of 2
