Activity › Forums › Avid Media Composer › capturing footage for a Demo Reel
Praxisseizure replied 20 years, 1 month ago 6 Members · 13 Replies
Rc Maples
July 10, 2006 at 7:27 pmRingabinn:
I’m not quite sure I understand how I would use the GL2 as a transcoder.Right now I have the video of the DVD as an AVI file and the Audio track as a Wave file, both on my Harddrive. So far I can’t get it to print to tape in either AXPro or Adobe Premeire.
So How would I need to go about using the gl2 as a transcoder? I’m not sure I’m following the work flow…
The way I see it would be to dump the avi/wav to tape and then re-capture it. I guess I’m missing something?
Anyway, Thanks for the help, mate.. Lemme know in a little more detail how to use the GL2 as a transcoder… Its connected to the box via FireWire.
Thanks in Advance,
RC—
Doobie Doobie Doo
beware the penguins -
Geraint Pari huws
July 10, 2006 at 9:13 pmPROABLY MISSING SOMETHING AND A LITTLE BEHIND BY NOW…
DVD ANALOG OR S VIDEO OUT TO YOU DV DECK/CAMERA – MENU SETTING OR SWITCH TO EXT VIDEO, e to e in old fashioned terms – load to avid with no deck control nor tc via firewire, ok no great quality but real time and codecless(ish!)
Praxisseizure
July 17, 2006 at 7:02 pmholy smokes. try after effects. it usually takes most files and you can crop or add lines to alleviate the 720×480 vs 720×486 issue easily.
also be careful about what field order you bring it in at. do a frame by frame test with a project at 59.94fps and see if there is any jitter. if there is, then drop the picture a single pixel to reverse the field order, and all should be well.
t!
