Activity › Forums › Apple Final Cut Pro Legacy › Capturing 1080p into FCP problems
  • Rpfloyd
    May 2, 2007 at 10:51 pm
    Hit the nail on the head. know that with any uncompressed format its always a good idea (if not absolutly necessary) to be running dual fibre/dual controllers to the spindles. fully loaded Xserve RAID 14 x 500GB drives DAS should get you around 120-160 MBs per controller = 240-360 MBs per RAID theoretically. The more you diminish the Drive modules per Controller the greater the performance decrease.
  • Jeremy Garchow
    May 3, 2007 at 5:24 am
    [moodyglasgow] “I tried 1080p DVCPro HD, and that worked. I’m not thrilled about using that format, but this project is a freebie, so I’m not going to lose too much sleep over it.”
    Oh man, go for it. It’ll be all good. DVCPro HD is clearly exactly what you need here, unless you feel like populating your entire array on your job you are doing for free.
    Jeremy
Page 2 of 2
