Activity Forums Adobe After Effects Expressions Capture number of lines in Paragraph Text for expression
  • Capture number of lines in Paragraph Text for expression
    Posted by Troy Poirier on January 24, 2019 at 9:07 pm
    I’m looking for a way to find the number of lines in a paragraph text box.
    The text is dynamically generated when I create a new composition or modify the composition name. It pulls the text from TSV data in a separate composition, and all the text flows/wraps in the paragraph text to create anywhere from 1 to 8 lines of text. I have a null object with a slider that I manually input the number of lines (needed for an animation unrelated to this question), but having this variable propagate automatically would save me time, as every week I need to update this slider within multiple compositions.
    I looked into the following options :
    1) Range Selector : obviously knows how many lines (“selector(“Range Selector 1”).end“) with “index” and “lines” set, but once set, the “end” number does not update with the new text.
    2) Expression Selector : knows how many lines and uses the variable “textTotal” to do the math, but I cannot figure out how to extract that variable for use elsewhere in the composition.
    Can’t seem to find an answer to this but I feel like it should be possible; and maybe I am way off and After Effects just doesn’t allow for this. Any help appreciated.
    Andrei Popa replied 1 year, 11 months ago 10 Members · 13 Replies
  • 13 Replies
  • Alex Printz
    January 24, 2019 at 9:27 pm
    you could do something like measuring the height of your text box and dividing by the height of the leading between lines:
    var t = thePathToTheTextObject;
    var h = 12; //make this a size appropriate to the line height in pixels; can’t pull dynamically from character panel;
    var n = text.sourceRecAtTime(time)/h;
    n.toFixed(0)
    I would suggest rigging h to a slider and test until it seems right, and then keep it there until it (might) break.
    Alex Printz
    Mograph Designer
  • Alex Printz
    January 24, 2019 at 9:28 pm
    whoops, that:
    var n = t.sourceRecAtTime(time)/h;
    n.toFixed(0)
    Alex Printz
    Mograph Designer
  • Troy Poirier
    January 28, 2019 at 3:50 pm
    Thank you so much, Alex! I don’t know why your specific code didn’t work for me, but you set me off in the right direction with sourceRectAtTime(). I found a similar chunk of code from Dan Ebberts elsewhere that led me to the solution below. Only oddity in this code was that I had to add a “padding” variable in order for the position value to match the manual setting I had before. Not a big deal, and this saves me so much time!
    // text layer
    t = thisComp.layer("text");
    // paragraph text height
    r = t.sourceRectAtTime(time,true).height;
    // font line height + padding
    y = 75;
    p = y + 5;
    // paragraph height divided by line height = # of lines
    n = r/y;
    // removes any decimals
    n = n.toFixed(0);
    /* code below spits out the Y Position values
    for my 2 keyframes based on knowledge of
    how many lines, up to 8 lines */
    lines = 340 + p;
    c = 0;
    do {
    lines = lines - p;
    c++;
    while (n > 1 && n < 9 && n != c);
    lines;
    if (numKeys > 1){
    k1 = key(1).time;
    k2 = key(2).time;
    v1 = lines;
    v2 = 473;
    linear(time, k1, k2, v1, v2);
    } else {
    value
  • John Millington
    October 23, 2019 at 6:41 pm
    Thanks for posting your code Troy ☺
    I was getting an expression error on the line with the while loop, but it looks like it’s because when the code is posted here, the less-than sign < is converted to a HTML entity & l t ; ( I’ve added spaces so it doesn’t change to the < symbol).
    Just replying in case it helps someone else.
  • Andrei Popa
    October 28, 2020 at 4:55 pm
    Just in case someone still needs this today.
    I needed to count the lines, stumbled on this solution and noticed some things were added by Adobe to after effects in the meantime.
    I tried this solution and it worked perfectly with any type of font/fontsize/leading.
    L = thisComp.layer("Text Layer");
    var newStyle = L.text.sourceText.style;
    var myLeading = newStyle.autoLeading ? newStyle.fontSize * 1.2 : newStyle.leading;
    H = L.sourceRectAtTime(time, false).height;
    rowNo = Math.ceil(H / myLeading);
    rowNo;
    You may need to replace the first row with a link to your actual text layer.
  • Gerald mark Soto
    December 18, 2020 at 5:18 pm
    thank you so much. needed this. can I ask why the use of 1.2 in the expression. how does that help find the answer?
  • Andrei Popa
    January 6, 2021 at 2:21 am
    The autoleading value is 1.2. And sometimes when leading was different value but then set to autoleading, the expression took the value before the autoleading. So I have put that condition. If autoleading is true, than leading is fontsize*1.2
  • Kane Daniel
    April 22, 2022 at 5:38 am
    Thanks so much! This works perfectly. Thanks for posting.
  • Tim Parsons
    March 20, 2023 at 6:27 pm
    I’m getting error codes that say that
    “property or method named ‘style’ in Class ‘sourceText’ is missing or does not exist.” Same for autoLeading, fontSize, etc.
    In my text layer, I don’t see these variables, and have no idea how to tell AE to either show them or know where to look for them.
    Any ideas?
  • Dan Ebberts
    March 20, 2023 at 8:17 pm
    I’m guessing that you either have an old version of AE or you have File > Project Settings > Expressions > Expression Engine set to Legacy ExtendScript instead of JavaScript.
