Activity Forums Adobe Premiere Pro Capture from Sony j-H1?
  • Dale Kutzera
    December 10, 2017 at 12:50 am
    So the D3, Monitor, and RS232C plugs are no use in exporting HD?
  • Shane Ross
    December 10, 2017 at 1:12 am
    No…D3 is a data port, not sure what MONITOR is… The only video out ports on that are the Composite and Component. But the Component is HD. There is a such thing as Component HD. I have a monitor with HD COMponent inputs
    Shane
    Little Frog Post
  • Brent Marginet
    December 10, 2017 at 1:14 am
    The BlackMagic Intensity may be a good option for you.
    There’s a USB 3 and Thunderbolt version available and they start at $200.
    \”MY MEDIA/PROJECT MOTTO: If you think three copies of your Media or Projects are enough. Take a moment to place a value on them and then maybe add two more.
    Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN\’T.\”
  • Andy Patterson
    December 10, 2017 at 11:14 pm
    [Brent Marginet] “The BlackMagic Intensity may be a good option for you.
    There’s a USB 3 and Thunderbolt version available and they start at $200.”
    As long as he gets the BNC to RCA adapters I think it should work. The only thing is the Intensity Pro 4K can offer capture of 1920 X 1080P at 60 FPS. The Intensity Shuttle will not capture 1920 X 1080 at 60 FPS. Not sure if 60 FPS is needed or not. I also think you can purchase the BNC breakout cables separately with the Intensity Pro 4K version.
    The video below might be worth watching.
    https://youtu.be/LOqTFH3PSE4
  • Shane Ross
    December 11, 2017 at 2:22 am
    [andy patterson] “The Intensity Shuttle will not capture 1920 X 1080 at 60 FPS. Not sure if 60 FPS is needed or not.”
    The only 60fps tape format there is is 720p60. 1080 on tape is always 29.97 or 23.98.
    Shane
    Little Frog Post
  • Dale Kutzera
    December 11, 2017 at 3:40 am
    Thanks. I’ll look for an Intensity card. Still overall much cheaper than having a house transfer all these tapes.
  • Andy Patterson
    December 11, 2017 at 4:24 am
    [Shane Ross] “[andy patterson] “The Intensity Shuttle will not capture 1920 X 1080 at 60 FPS. Not sure if 60 FPS is needed or not.”
    The only 60fps tape format there is is 720p60. 1080 on tape is always 29.97 or 23.98.”
    I am hip. I think the Intensity Shuttle will work OK. I am just hinting that for the price it might be better to get the Intensity Pro 4K because it has a lot more options than the Shuttle. I admit you would need an empty PCIE X4 slot.
  • Brent Marginet
    December 11, 2017 at 5:11 am
    HDCam cannot do 60 progressive fps the max it can do is 60i so the Intensity Shuttle will be perfect for his needs.
  • Brent Marginet
    December 11, 2017 at 5:25 pm
    Just as an FYI, the Monitor Output on that deck is for a VGA Computer Monitor.
    I believe that it worked with a 1024×768 Monitor but if I remember correctly the video looked pretty bad through any monitor.
  • Dale Kutzera
    December 11, 2017 at 11:53 pm
    Yeah I ‘ve hooked the deck to a monitor via that output and happily the deck works fine, but the video is rather “speckly” for whatever reason.
Page 2 of 3
