Activity › Forums › Apple Final Cut Pro Legacy › Capture Card: Blackmagic or AJA?
  • Chris Borjis
    September 4, 2009 at 4:50 pm
    [Tony Brittan] “Another vote for the Matrox products! Use MXO2 every day.”
    I forgot to mention I had an mxo and it did a much better job at 720P down conversion.
    I wonder if you guys that say the bmd does good down conversion have noticed
    angles with aliasing. thats what I clearly see. QC is one of my primary duties
    so I scrutinize everything.
  • Shane Ross
    September 5, 2009 at 11:41 pm
    [Loren White] “Are all of the outputs active? For example.. can I run a display out of the SDI output and a monitor out of the HDMI output at the same itme?”
    Yup. ALL outputs. YOu can output HD SDI to an HD monitor, HDMI to a client monitor and SD out via composite or component to an SD TV.
    Shane
  • J. Tad newberry
    September 6, 2009 at 4:01 am
    So after a full day (well, almost) of dandy editing with nice color pictures on my monitor, i turned off my UVW-1800 deck, and when i turned it back on, i got ye olde black and white (and a bit jumbled) monitor pix again! Trashed FCP prefs, restarted, no change. This is very strange. I would call BMD tech support, but i don’t think such a thing exists…especially on the weekends. Very very weird.
    Thanks again!
    J. Tad Newberry
    Big Ya Productions
    Mac Pro 2.66 GHz Quad-Core
    3 GB RAM
    http://www.bigya.tv
  • Shane Ross
    September 8, 2009 at 6:16 pm
    [Loren White] “Hey Shane, can the MXO2 output 2k to a 2k display? “
    Only the Kona 3 does that.
    Shane
Page 4 of 4
