Activity › Forums › Adobe Audition › Capture audio from from soundcard
Geoffrey Apple
September 17, 2011 at 3:45 amHi, I mainly know what you want to do. While you are watching videos on your computer, you could try to record sound from PC sound card by the use of a lot of soundcard recorders such as Audacity, Adobe Audition and streaming audio recorder. If you find Audition is a little complicated, you may go to use other ones.
Adrian Stiegler
September 21, 2018 at 2:28 amUse VB Cable.
I was always having a hard time recording what I hear in windows with my external audio interface. This installs an input/output in your Sound panel which you can set for both playback and recording.
https://www.vb-audio.com/Cable/
Works like a charm!
If you want to hear what you are recording in windows through your speakers, set ‘Listen to this device’ by right clicking on the new output channel in your Sound/Recording window created by this app and checking ‘Listen to this device’, then in the drop down select your output/speakers.
Cheers!
