Activity › Forums › Adobe After Effects › Can’t see my null objects anymore – oh, why?
Posted by Vera Duffy on May 30, 2009 at 10:21 pmHi AE geniuses, I recently migrated to a new iMac, and for some reason, I can no longer see my nulls. They’re there, but the square is invisible. Does anyone know why? I’ve done my research and have found no explanation. I fear it’s as simple as having hit some button; I also fear it’s not that simple. Are there any heroes out there who have an answer for me – it’s so very frustrating.
Some facts: AE CS3 8.0.2.27, iMac OS 10.5.6
Thanks!!
VeraJonathan Acosta replied 6 years, 2 months ago 9 Members · 12 Replies -
Jon Geddes
May 31, 2009 at 3:36 pmIf you see it in the composition, turn on the little eyeball to the left of the layer. Did that solve your problem?
Jon Geddes
Motion Graphics Designer
http://www.precomposed.com -
Vera Duffy
May 31, 2009 at 8:07 pmThanks for replying. Sadly, that’s not the problem; the eyeball is on. I only know the null is there because I can still use it – for example, parenting it to a camera then moving that around in a general sort of way. It’s the actual box and crosshairs that’s nowhere to be seen, and the problem is, I need to be able to position that box precisely for some of my work.
Very odd, yes? I’m really at a loss.
Stuart Elith
June 1, 2009 at 12:15 amAre all your other footage boxes showing up? Perhaps you simply have disabled the Toggle Mask and Shape Paths.
The hotkey to switch it on or off is Cmd + Shift + H, or you can see the switch at the bottom of the comp window, next to the timecode.
Vera Duffy
June 1, 2009 at 1:39 amHm, that doesn’t seem to be it either. I took a screen shot, perhaps there’s something obvious I’m not seeing? https://www.alotofduffysfilms.com/no_null.jpg
Sorry for the bother, thanks for helping!
Vera Duffy
June 16, 2009 at 11:02 pmGood news – your post prompted me to give this another shot, and it looks like I had things turned off under View – View Options… I turned everything on and made sure View -Show Layer Controls was on (checked). Not sure which did it, but every thing’s visible now. I can’t remember turning anything off – so annoying : )
Let me know how this works for you!
Vera
Metta Xu
February 13, 2012 at 10:23 amStuart,
You are a life saver- Your simple solution saved me another 2 hours of hunting for my disappearing null object… Thanks again for sharing. -
Lars Kristoffersen
April 12, 2012 at 10:09 amI was battling this one for quite some time, and i managed to find the little rascal…
Select your comp view, pull down the little menu in the top right corner and select “View Options” (view options can also be found under the View menu and is grayed out unless your comp view is selected)
You get the View options menu and the one you’re looking for is “Handles” click it on and ok it.
Now you should be able to see the transform gizmo when you select the null layer. -
David Honan
April 30, 2015 at 12:02 pmI’m getting this problem too, che palle!!! Time to read this thread…
