Activity › Forums › VEGAS Pro › Cant render in sony vegas due to: “Warning, the source image has non-zero RGB values in pixel with zero in Alpha channel”
  • Graham Bernard
    March 3, 2014 at 6:06 am
    _______________________________________________________________
    [Norman Black] “Looks like you have twixtor in your effect chain?”
    Norman, I thought at first “Why would TWIXTOR be playing around with null RGB value pixels?“, but then again TWIXTOR certainly DOES build/make interim frames and maybe, just maybe . . .
    OK, I’ve always disabled resampling when using TWIXTOR and had great results (I have the latest TWIXOR6 and it is zippingly fast!). Just check and see if your TWIXTOR Event has re-sampling disabled?
    Grazie
Page 2 of 2
