Activity › Forums › Apple Final Cut Pro Legacy › Can’t Output Video on External Monitor
Emilio Santero replied 10 years, 6 months ago 8 Members · 20 Replies
Thaxter Clavemarlton
June 7, 2010 at 6:48 pm[Robert Martin] ” Is Apple aware of the issue? “
This thread is from about 5 years ago.
Let’s hope that similar issues have been addresses in the interim since 2005.
Matthew Harnick
July 6, 2010 at 4:32 amRob – perhaps you’re still in the know about this issue. I am having problems printing to tape. Using FCP 7 & a Sony M15AU deck. Cannot switch to ‘all frames’ under external video. Deck is connected fine, captures with no problem – just can’t output to tape. Any ideas – and I appreciate any you’ll have. Too frustrating.
Matt
Matthew Harnick
July 6, 2010 at 1:56 pmThat would explain a lot. So I’ll ask your advice then on archiving HDV footage – other than going to blu-ray. What are my options?
Rob Forsythe
July 6, 2010 at 3:54 pmYou CAN output to an HDV deck and tape using FW.
It is just (as I said) not a constant REAL TIME playback as DV is. -
Matthew Harnick
July 6, 2010 at 4:13 pmIf it’s not a real-time playback…what is it exactly? Sorry – after 15 years in video I find myself a newbie in this one area! And – if you’re amenable, I’d love to get an idea of how to do it, since I cannot. Again, completely connected, FCP recognizes the deck and I can capture just fine…just printing is the problem. Much obliged.
Rob Forsythe
July 6, 2010 at 8:20 pmYou’re really in the wrong COW forum and asking the wrong question.
You want to do a search for “HDV print to tape.”
Should be lots of info there.Or re-post your question in the following forums-
https://forums.creativecow.net/hdvformat
https://forums.creativecow.net/applefinalcutbasics
Billie Lofland
June 22, 2011 at 5:10 pmRob,
Thanks so much for your list. After switching from a Firewire to AV setup in FCP, I couldn’t see the timeline in my monitor. Checked cables to AJA card, no luck–panic was setting in. Then I found your post. Solution 2 was the answer to my problems.
Emilio Santero
March 14, 2016 at 4:53 pmStill life-saving 11 years after!
Thanks Rob!
Il dolce fare tutti.
