Norman Black
October 11, 2013 at 12:04 amWhat are the specs of the DV file the CUDA converter generated?
Rick Hughes
October 11, 2013 at 9:17 amHere is Mediainfo
General
Complete name : E:\Users\Rick\Desktop\BL.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 153 MiB
Duration : 56mn 24s
Overall bit rate : 379 Kbps
Encoded date : UTC 2013-05-10 14:04:08
Tagged date : UTC 2013-05-10 14:18:44Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L3
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 56mn 24s
Bit rate mode : Constant
Bit rate : 256 Kbps
Width : 352 pixels
Height : 288 pixels
Display aspect ratio : 1.222
Frame rate mode : Constant
Frame rate : 29.970 fps
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.084
Stream size : 101 MiB (66%)
Language : English
Transfer characteristics : BT.601
Matrix coefficients : BT.601Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 56mn 24s
Source duration : 56mn 24s
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Stream size : 50.9 MiB (33%)
Source stream size : 50.9 MiB (33%)
Language : English
Tagged date : UTC 2013-05-10 14:18:44 -
Bob Jordan
November 3, 2014 at 7:18 amThe headache issues with Sony Vegas dealing MP4 files may causes by hardware issue or codec issue. First make sure your computer is powerful enough and has enough disk space as Sony Vegas requires your computer be powerful enough and have enough disk space for video editing. That’s to say, if your source files are quite large and you won’t have enough space on the output folder, Sony Vegas will not import MP4 files.
If your computer is powerful enough and you have enough space on your hard drive, but still have problem of loading MP4 video to Sony Vegas, the issues can be caused by the unsupported audio and video codecs packed in the MP4 container. you’d better transcode MP4 to a format editing-friendly format, such a Vegas’ MPEG-2. Here is a workaround for you: https://format-compatible.blogspot.com/2014/10/how-to-use-mp4-files-in-sony-vegas-pro.html
Savvas Lelekis
June 17, 2015 at 11:45 amI had the same problem.
The only think I had to do is to install Quicktime 7 and my problem is solved.
Better look on forums before posting because there are already many treats like this in the internet. -
Chris King
July 21, 2015 at 9:02 amActually, Sony Movie Studio supports MP4, but it only prefers MPEG-4 codec instead of others. However, MP4 as a container format can include various video codecs. So if your MP4 files are not accepted by Sony Movie Studio, it’s probably because of the video codec incompatibility. To get rid of the trouble, you need to transfer MP4 files to Sony Movie Studio preferred codec and then import to Sony Movie Studio for editing.
