Activity › Forums › Adobe Premiere Pro › Can’t access source settings on some R3D clips
Peter Szijarto replied 10 years, 8 months ago 7 Members · 11 Replies
Peter Szijarto
December 12, 2015 at 11:35 pmHey everyone here is a solution to adding a source setting to a bin of clips.
Double click on the clip you want to adjust from the project window bin.
Then go to effect controls. Click on the top left tap and that’ll be the masterclip setting. You can adjust there. You can also save a preset (which is saved into the effects window under preset, that you can drag on to a clip on the timeline if you wish).
After you’ve adjust your red clip (in my case all clips were shot on a white cycc, so they could use the same footage), click on “red source settings” that is in the Effect Controls window.
Then go to your bin of red clips in the project window, select the ones you want to affect, right click, hit paste, voila. You have adjusted the source settings for all those clips!
ALSO, you can right click on a RED clip (or select multiple clips) in your Project Files window, the click on “Disable Masterclip Effects” and you’ll have the old source settings option from CC 2014 become ungreyed and available again.
Peter Szijarto Director | Editor | Producer
pigsalreadyfly :: creative & post
http://www.pigsalreadyfly.com
