Activity › Forums › Apple Final Cut Pro Legacy › Cannot Repair Permissions!!!!!!!!!
Rafael Amador replied 18 years, 7 months ago 6 Members · 24 Replies
Jeremy Garchow
February 19, 2008 at 6:14 amHey Patrick.
As has been said, the point of rebuilding your system is to do just that, rebuild your system without problems. You do this once and do it right, you should be cool.
First, do the clean install of Leopard. Then do the software updates to being you up to the latest greatest of all the OS stuff.
Then start with FCP, install it, then do the software updates, multiple times.
Install any capture card drivers at this time. Then stop installing and see how everything is going.
Jeremy
Rafael Amador
February 19, 2008 at 11:40 amHi Jeremy,
I have to install for the first time Leopard, then FC 6.02. Which QT version is recommendable?
I will start to edit EX-1 stuff and archiving in Blueray. Many new little things to install.
I know FC is working fine, but I don’t want to mess with QT.
Thanks.
RafaelPPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE -
Jeremy Garchow
February 19, 2008 at 1:55 pmIf you are doing a fresh install, I’d go up to 7.4.1. Try to avoid 7.4.0.
Jeremy
Rafael Amador
February 19, 2008 at 3:06 pmThanks Jeremy. Ill do so.
