Activity › Forums › Apple Final Cut Pro Legacy › Can you output timecode with Final Cut?
  • Jeremy Garchow
    February 7, 2011 at 7:57 pm
    [John Heagy] “Connect the KiPro to your ProTools machine, via RS 422, and put the KiPro in remote. The KiPro will slave to your ProTools timeline and output video via any of it’s many outputs.”
    Just curious John, but have you tried this?
    Jeremy
  • John Heagy
    February 7, 2011 at 10:19 pm
    [John Heagy]” “Connect the KiPro to your ProTools machine, via RS 422, and put the KiPro in remote. The KiPro will slave to your ProTools timeline and output video via any of it’s many outputs.”
    We’ve controlled a KiPro via RS-422 with FCP/Kona3 and a DaVinci 2K and it syncs first time every time. I also tried it with a Sony 9100 edit controller and while it cues, jogs and plays, it will not sync. This is not too surprising as Sony’s protocol is “to the letter” including command received timing and machine ballistics.
    I have not tried it with ProTools, we use Fairlight.
    I suppose I should revise my statement from “will slave” to “should slave”.
    John Heagy
  • Jeremy Garchow
    February 7, 2011 at 10:31 pm
    [John Heagy] “I suppose I should revise my statement from “will slave” to “should slave”.”
    And perhaps the “not so easy button”? 😉
  • John Heagy
    February 7, 2011 at 11:17 pm
    We’ve used the KiPro aka: the “Easy Button” to solve many file<>tape requests. It’s a perfect tape replacement in many cases and much less “virtual” than Gallery’s VirtualVTR. While syncing to a ProTools timeline may not be guaranteed, all Tim needs is a solid LTC output for the ProTools timeline to sync to. This the KiPro can definitely do.
Page 2 of 2
