Activity › Forums › Adobe After Effects › Can i render a project in sections?
Jasford Muldoon replied 8 years, 6 months ago 5 Members · 12 Replies
Jasford Muldoon
March 7, 2018 at 6:35 pmthanks walter I really need to improve how i organise all ym folders, that is very amatuer of me to overlook that and the point oof saving the auto saved project as a new one is very wise, thank you.
I only render it in AME because AE will always crash without fail when I render it in there,.
Thanks Walter hopefully I can get this figured out. -
Jasford Muldoon
March 7, 2018 at 6:38 pmHeres what makes the least sense in all of this Joe, it always crashes at a point in the render than has no 3rd party plug ins, just a few plug ins used to make a transition that occurs over two adjustment layers.
I will have to keep at it and see if your advice about looking for the frame it freezes in the preview, hopefully I can figure this out, the only thing I can think, which has just come to me is that the motion blur that i turned onn on the adjustment layers might bne causing, if i remember rightly the transition uses AE’s motion blur but idk I can try disabling it to see if it renders but then how do i render it with the motion blur if that turns out to be the issue
