Activity › Forums › Apple Final Cut Pro › Can FCP create actual stills instead of the freeze frame mode?
Doug Metz replied 9 years, 8 months ago 7 Members · 13 Replies
Jonny Cates
January 6, 2017 at 7:20 pmThanks for you help Warren….found the answers I was looking for. Quicktime does it again….
Jonny Cates
Mark Smith
January 6, 2017 at 7:37 pmFor some time I underutilized the timeline index until I had to solve this problem on one of my own projects, and discovered just how useful the TL index can be…. I happy it helped you out.
Doug Metz
January 6, 2017 at 9:12 pm[Scott Witthaus] “Can’t you just “Save Current Frame” under the Share menu and go the the settings and select PNG?”
Indeed you can, but you have to add it to the Share menu in Preferences first.
Another handy tidbit in FCPX Preferences – right-click on your desired ‘Share’ method and set it as the default. Then you can simply use ‘Cmd+E’ to export your frames.
Doug Metz
Anode
