Activity › Forums › Adobe Premiere Pro › Can create an HD sequence for broadcast
Chris Franklin replied 13 years, 4 months ago 5 Members · 18 Replies
Tom Daigon
May 2, 2013 at 11:49 pmSounds like a good plan. When I first started using PrP I also kept looking for presets I coundt find. Then I realized I didnt really need them.Good luck!
Tom Daigon
PrP / After Effects Editor
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid
http://www.hdshotsandcuts.com -
Chris Franklin
May 3, 2013 at 2:19 amI have exported and set my frame size to 1280 x 720 to match my sequence. When it exports, the frame looks to be the right size, but it’s adding black bars on the sides.
Thoughts?
Ivan Myles
May 3, 2013 at 2:28 pmWas the aspect ratio set to square pixels? It would be helpful if you could post screen shots of your sequence settings and export settings.
Kris Merkel
May 3, 2013 at 3:30 pmI might have missed it, but what is your source footage and workflow?
“Think of everything in terms of building capacity.”
Kris Merkel
twitter: @kris_merkel
Product Manager, Flanders Scientific Inc.
http://www.shopfsi.com
Co-Founder, Atlanta Cutters Post Production User Group
http://www.atlantacutters.com2.2Ghz MBP core i7
16Gb RAM
CS6/FCP7
AJA T-Tap
AJA IO XT
FSI LM-2461W/CM-170W -
Kris Merkel
May 3, 2013 at 4:20 pmyour pixel aspect ratio should be set to square 1.0 (like your source), unless .9 is a deliverable requirement. Also HD fields are almost always upper. To help speed things up, just take a 2 second region to test out your compression settings.
It would help if you could share the deliverable specs.
Kris Merkel
16Gb RAM
CS6/FCP7
AJA T-Tap
AJA IO XT
Ivan Myles
May 3, 2013 at 5:02 pmThank you for posting the screen shot. Your export settings don’t match the sequence settings:
Aspect Ratio: Square Pixels (1.0)
Field Type: Progressive
Frame Rate: 30.00 FPS (although 29.97 will work)
