Activity › Forums › Adobe After Effects › camera tracker issues
  • Victor Camacho guerrero
    August 30, 2012 at 1:33 pm
    that is the funny part. I did that already and does not match at all.
    Is there any parameter that i am putting wrong?
    August 30, 2012 at 1:43 pm
    I think I found the reason. If I place my 3d object and I change the position to place it in the right place , my tracked data goes to hell. I can only change the size and rotation.
    How can i place the elements in the right place?
  • Tudor “ted” jelescu
    August 30, 2012 at 4:21 pm
    Let me clarify a few things:
    1- Your track data generates a camera solve- that creates a camera that matches the real world camera. Do you have the exact details as far as lens type, distance and “film” size or are you just eye-balling it?
    2- When you adjust the Element object position, are you adjusting the World position or using the controls under the Particle Replicator?
    Tudor “Ted” Jelescu
    Senior VFX Artist
    August 30, 2012 at 4:28 pm
    1- Unfortanely I am doing it by eye-balling it, because i dont have any detail from the camera.
    2 – I tried with both and both poor result.
    One thing I understood after loads of times, is that if i set my ground floor where exactly i want to place my element 3d , the track works well, however if i start to move the element to fit properly, the more i move , the more goes to hell.
    Which gives me another headache, how can i put two elements???
    this is the video in particular:
    https://vimeo.com/48535837
    I want to place some 3d text in the left bank and another 3d text in the right bank.
    If the video does not load, wait 30 min please, it is still uploading.
    Many thanks
    August 30, 2012 at 4:45 pm
    What version of AE are you using?
    The video is not up- I’ll take a look later.
    You should create a Null by selecting the track points that correspond in the footage with the place where you want your 3d text to be.
    In Element use the controls under the Particle Replicator to position the object. Once the position in matched, the only thing you need is to rotate and re-size, there should not be a need to move the position.
    For the second text, choose other track points, generate a second Null and use that as a reference to place the second object in Element that should be assigned to a different Group.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Shaun Myatt
    September 3, 2012 at 5:28 am
    i have this exact same issue, and to be honest Ive done all of the above as standard, yet my object still floats on the z plane, regardless of using the replicator x,y,z and using the null position figures in said mentioned particle replicator, ive also corrected my lens, I’ve entered the pixel pitch, sensor size, aspect ratio etc etc, my track is bang on, and in Boujou the test object is 100% solid, so i don’t understand.
    once both the corrected footage is in AE as well as the tracking cam data its meant to be just a case of creating an element layer via solid, and using the null (once un-picked) for the position data for the particle replicator, and then creating another null parented to the original nulls and camera to move the object, at least that’s how Kramer does it..the weird thing is, it gets worse as the camera comes into the middle of the move ie when it starts its not really floating, as it starts moving faster, it starts floating faster, yet its working in the sense of x and y, this is a major problem as I’ve been trying now for 4 days
    September 3, 2012 at 10:33 am
    Hey Ted,
    thanks a lot, sorry for the late reply butI have been working on find out which is the problem.
    I kept trying with the way you say, but i couldnot. Sorry
    As they say here:
    https://www.videocopilot.net/forum/viewtopic.php?f=42&t=90308
    this is pretty much a bug that will be fixed in the next update.
    For now the only solution is setting up your floor scene where you want to place your element 3d, and there just changing the scale and rotation, once you start to change the position, it gets messed.
    shaun for you, my recommendation is using camera tracker and setup your ground plane where you want to place your object.
    People in the forums say the plugin does not work well with pan shots.
    I found this as well.
    https://www.youtube.com/watch?v=CREoR1NciGk
    By the way, someone know how to see the element 3d in 3d views?
    many thanks
Page 2 of 2
