Activity › Forums › AJA Video Systems › Calibrating and HD LCD monitor with AJA color bars?
Ron Thompson replied 19 years, 3 months ago 10 Members · 19 Replies
Tony
May 27, 2007 at 6:07 pmMichael,
The most accurate method to calibrate any professional CRT or LCD monitor is to use a monitor probe to set up the gain,bias contrast using established SMPTE monitor alignment specifications (assuming your are doing work in a country which comforms to SMPTE specs).
The SMPTE monitor specs are available as a white paper. Look up SMPTE RP-166, RP-167 etc. A monitor probe looks like a suction cup which attaches to the monitor screen to read the monitor display values. The probe actually has an meter “eye” in it to “sense and see” the display values.
Professional monitors allow adjustments for gain and bias etc whereas consumers monitor will not henceforth why they are not suitable for high end color grading applications.
Gain and bias are the equivalents of white and black balance and allow balancing out the RGB guns so they are all equal. Green is generally used the reference channel and the user will calibrate the Red and Blue channels to Green.The number one reason why the whites or blacks on one monitor have a blue,red or green color cast when compared to another monitor is that the gain or bias is misadjusted. This will not be solved by setting up color bars to blue check. In fact have you ever noticed why color bars seen to be plus blue or red etc and regardless of what you do to the chroma or hue adjustment you never could quite get bars to look right? Well once again that is a good demonstration of the impact of gain and bias adjustments.
Aligning color bars via blue check is but one small part of properly calibrating a monitor for accurate and consistent color correction grading and/or judging exposure in the field.
Most of the information on the web regarding calibrating a monitor will center on using blue check without regard to the most important calibrations adjustments which are gain,bias,contrast. The reason being blue check is a “common man’s” method to quickly set up the monitor and most user’s are not using the monitor as a highly accurate grading monitor such as one found in a telecine color correction bay.In the world we live in today using an inaccurately aligned monitor in the field or even for use with Apple’s Color program or other grading system could lead to horrible and painful results if one does not use pre-established monitor reference alignment standards such as the SMPTE RP specs which professional facilities abide by. This is the only real method to allow for a unity reference which several facilities or users can share as a common point of reference and minimize client’s concerns about monitors on set or in the edit bay looking different.
A monitor which has not been calibrated with a monitor probe is one which should not be used for serious color grading or as an exposure reference in the field. Such consumer grade monitor are suitable for viewing content NOT GRADING COLOR OR EXPOSURE!! So always advise the viewer or client of this condition or instruct them to use the properly alignment monitor as the reference for critical decisions having to do with exposure,color etc.
I use a CRT monitor probe to calibrate the CRT monitors I use in the field or in the edit suite if I intend to use it as reference monitor. A monitor probe allows matching multiple monitors which makes life a lot easier when a DP desires to have an accurate monitor to look at which also matches the DIT or video controller’s engineering monitor.
Contrast adjustments are quite critical given that some LCD monitor such as an Apple cinema display can output such a high foot lambert 100 (FL) level well beyond the SMPTE 30-35 FL specs that you can be fooled into exposing inproperly. The process of judging contrast by eye and memory is not recommend for inexperienced users as their sense of where the contrast level looks right could be quite off compared to the SMPTE spec of 30-35 FL. A monitor probe will measure the FL values and verify once you have reached the proper FL values.
Nailing the proper exposure in the field cannot be done correctly if you have not calibrated contrast and brightness properly henceforth why a monitor probe is a necessary item to truly allow using a monitor as a critical reference guide in addition to a waveform monitor.
Note that for long term repeatability using a monitor probe to calibrate a monitor will always allow consistent results instead of using your memory to wing it by guessing how good the monitor looks from time to time. No one’s memory is quite as accurate as an instrument which accurately reads the monitor display values without regard to external distractions. The monitor probe I use has a numerical readout which easily allows hitting specific alignment marks time and time again.
The are a number of different vendors which make monitor probes so I advise doing a google search and get some feedback on which monitor probe suits your application,budget, and requirements.
Tony Salgado
Bob Zelin
May 28, 2007 at 12:19 amJust remember this, boys and girls. One of the most commonly used monitors in the history of post production – the Sony PVM-20M2U and the Sony PVM-20M4U, came misaligned from the factory (the black bias was misaligned, and all factory new PVM20M2U and M4U looked green in the blacks). Everyone bitched about this, but almost NO ONE ever got the monitor properly recalibrated, and for 10 years, people had a green tint in their blacks – they got used to it. (And this was in NY, for the ultra critical TV commercial market). And now, you want to stick a calibration gun on a consumer Sony XBR. Come on !
We will look back on this 5 years from now, when LCD monitors actually work, and we will say “remember when we actually tried to color correct standard def material on the early LCD monitors”.
Bob Zelin
Tony
May 28, 2007 at 12:37 amBob,
Just to be clear I am not suggesting wasting any time probing a consumer monitor but if you have a lot of time on your hands do whatever you see fit.
FYI everyone when a monitor is turned off the gain and bias will drift. Which is why most high end facilities leave their monitors on all the time for greater stability.
If you don’t do this then probing before an important color grading or production shoot session is paramount after the monitor has been allowed to heat up.
My point is if you as the end user are willing to accept and maintain your own quality control standards within established industry guidelines the end outcome will be long term repeatable results in spite of what the folks in NY Bob mentioned are willing to live with.
Must be a East coast thing cause here on the West thing are mighty different. Reminds me of when East Coast and West Coast on line editors had a feud over editing on field one or field two first.
Tony Salgado
Richard Dee
May 29, 2007 at 9:16 amThis is a great thread –
Can anyone suggest someone in NYC that can come over and calibrate my 20L5 and 14L5?
Tony are you in NY?
Sam Zimman
May 29, 2007 at 12:52 pmyeah i got a would also love to hire someone to come over and adjust all our monitors as well.
thanks
-sam -
Mark Maness
May 29, 2007 at 2:49 pmHey guys…
Let me ask you this…
How are you getting SMPTE bars thru you Kona card? Are you coming out of FCP?
The reason I ask this is because the Kona card doesn’t have SMPTE bars built into it. Go figure. I have every other pattern know to man BUT not SMPTE bars. At the moment, I’m having to use FCP to do this until AJA includes these in their control panel.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey -
Ted Griffis
May 29, 2007 at 4:02 pmWhat kinds of monitor probes are you all using?
Can anyone recommend one that will do LCD and CRT.
We are working with a hand ful of Panasonic BT-LH1700W’s and Sony PVM 20M4U and PVM 14L2’s.
Any hardware suggestions and / or individuals who provide calibration as a service are greatly appreciated, thanks
Ted -
Tony
May 30, 2007 at 4:33 amHi Deadhead,
No I am not in NY.
My suggestion would be to find a major rental house which has a service department that can take on outside work.
Try Bexel for example.
They have the proper test gear (white and black square pattern generator) and monitor probe to do proper calibration for both HD and SD monitors.
I have my own probe which I use in the field or in post for any CRT or LCD which I intend to do any serious color grading or exposure judgements with.
Tony Salgado
Ron Thompson
June 1, 2007 at 1:44 amTony…
U definitely know your stuff!!
Nice working with you in LA earlier this year (G.Garvin).East Coast/West Coast beef??? Is this video production or 1990’s HipHop??
We lost Biggie and Tupac because of that! 🙂Hope you’re doing well. Nice to see you in the AJA forum.
Ron
