Activity › Forums › Maxon Cinema 4D › C4D equivalent of Trim Path in AE
  • C4D equivalent of Trim Path in AE
    Posted by Charles Brepsant on January 26, 2016 at 5:23 pm
    Hi everyone,
    A client came to me with an urgent query.
    They need to have the wireframe lines of a 3d model appear just as if you were trimming paths in AE.
    I have been looking for a way to do this but have not been very successful.
    Is there an easy way to do this in C4D and/or Element3D in AE ?
    This is the idea (imagining it in movement with lines appearing):
    Many thanks for anyone’s help.
    Charles
    Veronica Barron replied 2 years, 8 months ago 6 Members · 11 Replies
  • 11 Replies
  • Charles Brepsant
    January 27, 2016 at 5:20 am
    Note:
    I found a way to do this but it is really archaic and does not work for heavier models.
    Basically for each frame of my C4D animation, export paths of objects to Illustrator with the sketch and tool render module, import them in After Effects, delete the Fills and apply a trim path with a different percentage of completion to every layer/frame…
    I have tried this with an animation of a simple cube, it is doable although much long for the simple task it is. Then I tried using a heavier model with more paths and Illustrator didn’t even respond to my commands.
    Any ideas on how to do this? There must be a really simple solution…
    Thanks for your help…
  • Brian Jones
    January 27, 2016 at 8:28 am
    It would help to see your cube test (if you did make an animation) to see what it is you are trying to do
  • Charles Brepsant
    January 27, 2016 at 8:48 am
    Here is the cube example:
    9712_testcube.mov.zip
    Also, see seconds 00:19 to 00:20 of this video. That is basically the effect with a bigger 3d model
  • Charles Brepsant
    January 27, 2016 at 8:49 am
    sorry forgot to provide the link.
    see secs 19 to 20 of this video: https://www.youtube.com/watch?v=OZ-N3h40lPc
  • Brian Jones
    January 28, 2016 at 4:36 am
    animated Sketch and Toon – I know you can animate the strokes in but haven’t played with it enough in a while, sorry no time to test right now.
  • Charles Brepsant
    January 28, 2016 at 5:17 am
    Hey Brian,
    Thanks! I’ll check it out see if I can come up with something.
    Best
    Charles
  • Cassius Marques
    January 28, 2016 at 5:22 pm
    Can’t you select the edges that you want shown in cinema and convert them to splines and render from that? with sweeps?
    Cassius Marques
    http://www.zapfilmes.com
  • Charles Brepsant
    January 29, 2016 at 7:04 am
    Thanks Cassius.
    After some testing, both the methods work and both have their own advantages/disadvantages.
    Thanks !
  • Brian Eichenberger
    January 10, 2024 at 3:39 pm
    (8 years later. . .)
    in case anyone lands on this thread like I just did, you can trim paths in C4D.
    here’s a quick tip → https://www.youtube.com/watch?v=96GpfEiREoo
  • Kouraib Abdmalek
    January 10, 2024 at 8:01 pm
    Thanks for sharing that with us, Brian!
