Burnt-in timecode (BITC) generator effect (that simulates pro VTR)?
Rick Anvican replied 12 years, 1 month ago 3 Members · 18 Replies
Graham Bernard
August 1, 2014 at 12:06 pmDo you mean my approach? I use all the elements of VP, no Scripting or additional purchased s/w. As you wanted an “effect” it is purely that, an effect.
I can post the VEG file. What version of Vegas are you using?
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Graham Bernard
August 2, 2014 at 8:15 am[Rick Anvican] “Vegas Pro 12 (b770/x64)”
Done.
T/C is set for 23.97fps, but all you need to do is “change” the Timecode FX for what you want. All of the Vegas Controls are available and I’ve used then in the way SCS are expecting them to be used. It is ALL here.
This in Preview for Safe Areas:-
This is a VIEW of the Timeline layout with Track HEADER Notes:-
Here’s the VEGGIE for VP12 B770:-
7809_vtreffectforvp12b7701a.veg.zip
As I said, this IS for an “effect”.
Cheers
Grazie
Graham Bernard
August 3, 2014 at 9:23 amGood.
Did you understand the Project file?
Have you been successful in employing it?
Grazie
Rick Anvican
August 3, 2014 at 12:47 pmI opened the VEGGIE and was able to change TC framerate to 29.97fps which I’m using,
disabled the test pattern layer, saved it and imported it as a nested project,
working fine. -
Graham Bernard
August 3, 2014 at 1:08 pmExcellent!
Grazie
Rick Anvican
August 3, 2014 at 1:56 pmMuch appreciated, thanks again for taking the time to make the VEGGIE.
I’m sure other users will find this useful.
