Activity › Forums › DSLR Video › Building an audio system
Bill Doyle
October 12, 2010 at 11:53 pmTony,
I use one or two lavs plugged into the XLR inputs (they also accept 1/4′ and can accommodate condensers) and use the built-ins for backup and ambient room/environment sound. The XLR/1/4″ inputs have an independent signal adjustment from the built-ins.
Bill
Tony Connoly
October 13, 2010 at 10:50 amI’ve read about the slow start up time for the H4N. Does that mean that everytime you press the record button you have to wait, or is it only once per session? How long is the wait?
Bill Doyle
October 13, 2010 at 12:31 pmTony,
The wait is only for the initial power-up (approx. 15 seconds). Once it is on, you can hit record immediately. You can also set up a 2-second pre-record so you won’t miss anything.
Bill
Tony Connoly
October 21, 2010 at 4:30 amI went ahead and ordered an H1. I need to learn the basics.
