Activity › Forums › Adobe After Effects Expressions › Break a line of text in half to the nearest word
TIneke Van Schalkwyk replied 6 years, 1 month ago 2 Members · 16 Replies
August 1, 2020 at 4:49 amWorks great but unfortunately now the font style is not working…
Andrei Popa
August 1, 2020 at 7:39 amYou mean when there are line breaks in the text?
This is what it was built like. I told you you could replace the “value” with another piece of expression.So if this is the case, this should work.
function breakInTwo(myString) {
var mid = Math.floor(myString.length / 2);
var before = myString.lastIndexOf(" ", mid);
var after = myString.indexOf(" ", mid + 1);if (before == -1 || (after != -1 && mid - before >= after - mid)) {
mid = after;
} else {
mid = before;
return myString.substring(0, mid) + "\n" + myString.substring(mid + 1);
}if (text.sourceText.indexOf("\n") != -1 || text.sourceText.indexOf("\r") != -1 || text.sourceText.length<20) {
style.setFont(comp("00 Color Control").layer("Headline Text Font Style").text.sourceText.style.font);
} else {
val = breakInTwo(text.sourceText);
style.setFont(comp("00 Color Control").layer("Headline Text Font Style").text.sourceText.style.font).setText(val);
Andrei
My Envato portfolio. -
August 1, 2020 at 10:17 amSorry, no I meant this part is not working:
style.setFont(comp(“00 Color Control”).layer(“Headline Text Font Style”).text.sourceText.style.font).setText(val);
Andrei Popa
August 1, 2020 at 11:28 amI tested it like this. I made 2 text layers for text. I added this slightly modified version for the second one. It works as intended. But it does not change fontsize, color or any other properties. Yet.
mid = after;
} else {
mid = before;
return myString.substring(0, mid) + "n" + myString.substring(mid + 1);
}if (text.sourceText.indexOf("n") != -1 || text.sourceText.indexOf("r") != -1 || text.sourceText.length<20) {
style.setFont(thisComp.layer(1).text.sourceText.style.font);
} else {
style.setFont(thisComp.layer(1).text.sourceText.style.font).setText(val);
But if you also want to modify font size or other properties, you have to add some stuff to this expression.
This will be the base expression on which you can add properties.function breakInTwo(myString) {
var after = myString.indexOf(" ", mid + 1);if (before == -1 || (after != -1 && mid - before <= after - mid)) {
mid = after;
} else {
mid = before;
ctrlStyle = comp("00 Color Control").layer("Headline Text Font Style").text.sourceText.style;
style.setFont(ctrlStyle.font);
} else {
style.setFont(ctrlStyle.font).setText(val);
You can add properties by adding the following options at the end of the “style.setFont(ctrlStyle.font)” or the “style.setFont(ctrlStyle.font).setText(val)” parts.
// Set the font used to Arial
style.setFont(ctrlStyle.font)// Set the font size to 80
style.setFontSize(ctrlStyle.fontSize);// Enable Faux Bold with a Boolean
style.setFauxBold(ctrlStyle.fauxBold)// Enable Faux Italics with a Boolean
style.setFauxItalics(ctrlStyle.fauxItalics)// Enable All Caps with a Boolean
style.setAllCaps(ctrlStyle.allCaps)// Enable Small Caps with a Boolean
style.setSmallCaps(ctrlStyle.smallCaps)// Set the Tracking as a number
style.setTracking(ctrlStyle.tracking);// Set the Leading as a number
style.setLeading(ctrlStyle.leading);// Enable Auto Leading with a Boolean
style.setAutoLeading(ctrlStyle.autoLeading);// Set the Baseline Shift as a number
style.setBaselineShift(ctrlStyle.baselineShift);// Set the Stroke Width as a number
style.setStrokeWidth(ctrlStyle.strokeColor);
The list is taken from this adress https://helpx.adobe.com/after-effects/using/expressions-text-properties.html
So, as an example, if you also want to take the size and fill color from the original layer, the final expression will look this way
mid = after;
} else {
mid = before;
style.setFont(ctrlStyle.font).setFontSize(ctrlStyle.fontSize).setFillColor(ctrlStyle.fillColor);
} else {
style.setFont(ctrlStyle.font).setText(val).setFontSize(ctrlStyle.fontSize).setFillColor(ctrlStyle.fillColor);
I hope this was your problem.
Andrei
August 2, 2020 at 12:16 pmThanks!
I managed to fix it by changing the font part as I needed it pulling the font from the source text of the field not the font of the text field if that makes sense. So was an easy fix.
style.setFont(comp(“00 Color Control”).layer(“Headline Text Font Style”).text.sourceText).setText(val);
August 2, 2020 at 12:18 pmI’ve also got another thread for how we can make a version of this that allows for three lines if you wanted to also comment there.
https://forums.creativecow.net/thread/2/1144665
